Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#511 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 02:21 PM
Already received my order, it took less than three days?! wow
Edited by dasupersprint, 28 February 2020 - 02:22 PM.
#512 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 02:22 PM
New slave cylinder
#513 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 02:23 PM
New clutch master
#514 Syma
Syma
  • 73 posts
Posted 02 March 2020 - 01:58 AM
New clutch master
I had trouble with my brake and slave masters when I got them. I didn't know about bench bleeding to prime them before installing. I ran a short line from the outlets and back into the bottom of the reservoir, had someone pump the pedal until bubbles stopped. I got a 2' brake line from the parts store and cut it in half and twisted it to fit. Doing it this way the brake fluid is contained and less of a chance of a spill on the new paint. Of course use lots of rags just in case especially when disconnecting the short lines to connect your car brake lines.
Moss has some good videos on the process
I hate brake fluid
Edited by Syma, 02 March 2020 - 02:00 AM.
#515 dasupersprint
dasupersprint
  • 848 posts
Posted 02 March 2020 - 03:17 PM
New clutch master
I hate brake fluid
Oh, I didn't know that, anyways I installed both of them and now the lines are full of fluid, I'll have to bleed them like that because, like you, I loathe brake fluid
#516 dasupersprint
dasupersprint
  • 848 posts
Posted 02 March 2020 - 03:20 PM
Old vs new: Brake master
#517 dasupersprint
dasupersprint
  • 848 posts
Posted 02 March 2020 - 03:21 PM
Had to cut the ends of the new lines to put my 3/8'' fittings
#518 dasupersprint
dasupersprint
  • 848 posts
Posted 02 March 2020 - 03:22 PM
Nice
#519 dasupersprint
dasupersprint
  • 848 posts
Posted 02 March 2020 - 03:25 PM
The clutch line is bled and it now works fine.
I found out that the old washer hoses were leaking, probably because they were hard and dry, so I replaced them with new ones. Now the washer bottle is the worst looking thing under the bonnet. I may do something about it later but it's really not the priority.
#520 dasupersprint
dasupersprint
  • 848 posts
#521 dasupersprint
dasupersprint
  • 848 posts
Posted 04 March 2020 - 01:55 PM
While investigating on the reverse lamp, I found that I put the yoke upside down in the gear shift mecanism?! That's why I felt the gear lever was really feeling loose. So I fixed that after removing the carpet, the gear lever, the split pin...
#522 dasupersprint
dasupersprint
  • 848 posts
Posted 04 March 2020 - 02:03 PM
And after testing the switch for the reverse lamp, I tested the current all the way to the rear but the lamp didn't turn on. Turns out that the bulb was just not pushed in properly.
#523 dasupersprint
dasupersprint
  • 848 posts
Posted 06 March 2020 - 06:14 PM
Got the chrome strip on the back window. Nice!
#524 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 06 March 2020 - 07:42 PM
Rest assured, you are not the only one to do that!
#525 dasupersprint
dasupersprint
  • 848 posts
Posted 09 March 2020 - 04:31 PM
Exhaust is now fitted
