Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#496 dasupersprint
dasupersprint
  • 848 posts
Posted 11 February 2020 - 05:56 PM
I disassembled the center gauge completely. For two reasons: The odometer was stuck at 49 999,9 km, and the glass was dirty from inside.
Edited by dasupersprint, 11 February 2020 - 06:04 PM.
#497 dasupersprint
dasupersprint
  • 848 posts
Posted 11 February 2020 - 05:58 PM
I unstuck the odometer, so that went well. But while assembling, dust accidentally  went into the speedo mecanism, so now it wouldn't work properly. I had to take it apart again, and much further to clean this up.
#498 dasupersprint
dasupersprint
  • 848 posts
Posted 11 February 2020 - 06:04 PM
While I had the odometer in hands, I thought well, I could try to reset it at 00 000 (it's legal with classic cars in Canada, the condition of the car is more important than the mileage).
Sooo, I broke it. The decimal wheel wouldn't turn the others when passing form 9 to 0. Oh well...
So I put everything back together with a good clean and that's it. If I had to choose I prefer a working speedo than a odometer. Maybe someday I'll find a replacement part.
Edited by dasupersprint, 12 February 2020 - 02:01 PM.
#499 Syma
Syma
  • 73 posts
Posted 13 February 2020 - 04:54 AM
Looking really really good. Been reading this for a long time and I am happy for you that its nearing completion.
#500 panky
panky
  • 1,792 posts
Posted 13 February 2020 - 11:34 AM
A little tip I learned when re-fitting the needle was to line it up with the little mark by the HB letters and then flip the neele back over the stop. This gives the correct tension on the needle and hopefully an accurate reading.
#501 dasupersprint
dasupersprint
  • 848 posts
Posted 13 February 2020 - 02:41 PM
Thanks! In 4 weeks I could go to the technical inspection to get it approved for the road. It's my current goal, so if there's something wrong with it, I would be able to fix it before summer.
There may be a big step this weekend...to be followed
#502 dasupersprint
dasupersprint
  • 848 posts
Posted 14 February 2020 - 01:37 PM
I put KAD steering rack stops to keep the tires from touching the inner wings when fully turned.
#503 dasupersprint
dasupersprint
  • 848 posts
Posted 18 February 2020 - 01:52 PM
So here's the big step:
Had a Mini-friend who has an engine hoist came by saturday. For now, there's one drive shaft, the shifter linkage and two engine steadies connected.
#504 dasupersprint
dasupersprint
  • 848 posts
Posted 21 February 2020 - 02:05 PM
Slowly dressing up the engine bay. Connected all wires except the engine ground. Put the big Canadian fan in
#505 dasupersprint
dasupersprint
  • 848 posts
Posted 21 February 2020 - 02:07 PM
I learned the hard way that it would have been easier to put the hose on the slave cylinder on the engine first
#506 Syma
Syma
  • 73 posts
Posted 23 February 2020 - 12:41 AM
I really wish I did this on mine
#507 dasupersprint
dasupersprint
  • 848 posts
Posted 27 February 2020 - 01:38 PM
Brand new washer pump
#508 dasupersprint
dasupersprint
  • 848 posts
Posted 27 February 2020 - 01:40 PM
Also installed the second drive shaft. Tried to bleed the clutch hydraulics and found that the master doesn't push any fluid. So I have an order coming with the clutch master, slave cylinder and while at it, brake master.
#509 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,040 posts
Posted 27 February 2020 - 08:35 PM
Great work! I would mount the washer pump the other way around, I mounted mine the way you have and after a while it stopped working due to water getting into the motor and rusting it solid.
#510 dasupersprint
dasupersprint
  • 848 posts
Posted 28 February 2020 - 02:20 PM
Well what are you talking about, it's already on the right side, just look at this picture  :gimme:
by the way thanks for the info
