Prepared the area for a new scuttle corner
Canadian 1978 Mini 1000 - Long Resto
#376
Posted 01 May 2019 - 07:26 PM
#377
Posted 01 May 2019 - 07:28 PM
While removing the A panels I didn't have choice to lose the lip that it sits on. So I had to build a new one.
I bended the A panel and made a mockup of the lip...
In place
#378
Posted 01 May 2019 - 07:29 PM
By the way, I just picked up a solid steel used "rover" bonnet as I found the one on my 77 is the flimsy after market stuff and never ever fits properly. I am changing as had a bonnet flip on the road as latch was not holding properly (pervious owner - ughh) and slightly dented it, impossible to fix as the aluminum is so thin feels like cheap cardboard paper?
Not sure if anyone else experienced the same.
#379
Posted 01 May 2019 - 07:30 PM
That area on the A post was very ugly so I prepared it for the A panel to sit on it.
A panel in place with nice door gap
Edited by dasupersprint, 01 May 2019 - 07:31 PM.
#380
Posted 01 May 2019 - 07:31 PM
Now came the time to fit everything at once
#381
Posted 01 May 2019 - 07:33 PM
I figured that something was too long between the A panel and the wing, so I settled on shortening the wing by about 1mm. I cut the flange and made a new one
#382
Posted 01 May 2019 - 07:34 PM
modified the scuttle corner a bit
#383
Posted 01 May 2019 - 07:37 PM
After much work with the wing, I was left with not too bad bonnet gaps. Everything was clamped and screwed, not welded yet.
#384
Posted 01 May 2019 - 07:39 PM
Now to the left side. The door by itself looked worse...
#385
Posted 01 May 2019 - 07:40 PM
I straightened the gap with welds
#386
Posted 01 May 2019 - 07:41 PM
This was bad, needed more violent solution
#387
Posted 01 May 2019 - 07:44 PM
I had the same problem with the wing being too long. I didn't need to remove the wing completely so I shortened the A panel this time
#388
Posted 01 May 2019 - 07:47 PM
Acheived good results.
#389
Posted 01 May 2019 - 08:21 PM
After everything was clamped and screwed together (not welded) I called back my body guy so he could come and take a look. After the second call I got tired of hearing his excuses so I won't call back...
I found someone else via another Mini guy and he came within days. I did not tell him my story and he said himself that when a car comes in his garage, he doesn't forget about it, he works on it. I already have a better feeling.
I started welding the front.
#390
Posted 22 May 2019 - 05:25 PM
Ok everything is welded and ready. I got most of the car to bare metal, except the roof and openings. It's ready to go to bodyshop #2
