Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#271 dasupersprint
dasupersprint
  • 848 posts
Posted 17 October 2018 - 12:40 PM
And drilled the holes in both doors for the side mirrors
#272 dasupersprint
dasupersprint
  • 848 posts
Posted 17 October 2018 - 05:26 PM
New rear seat belts are in
#273 dasupersprint
dasupersprint
  • 848 posts
Posted 18 October 2018 - 12:44 PM
Hard to tell with my crappy pics but the fuel pipe had been pinched on the heelboard when installed back in 2016. It has always bugged me. I finally took care of it by replacing that section with a flexible item.
Pinched corner nicely circled in blue
Flexible
The culprit
#274 dasupersprint
dasupersprint
  • 848 posts
Posted 18 October 2018 - 12:47 PM
Exhaust hanger installed on subframe
Next job is to drill two holes in the subframe to fit the exhaust back box
#275 dasupersprint
dasupersprint
  • 848 posts
Posted 30 October 2018 - 12:33 PM
There you go, nice
#276 dasupersprint
dasupersprint
  • 848 posts
New brake pedal switch. I broke the old one...
#277 dasupersprint
dasupersprint
  • 848 posts
Posted 30 October 2018 - 12:37 PM
Back in 2016 when I fitted the boot floor, I forgot to put the captive nut for the negative battery cable. I got the small bracket for it and, my bad, I thought it would come with the nut itself. So I had to include one myself, even if it's 5/16'' UNC. Can't find UNF in hardware stores.
Welded it over the boot floor. I know it's meant to go under it, but I really can't and it doesn't seem to be a problem
#278 GraemeC
GraemeC
  • 7,421 posts
Posted 31 October 2018 - 06:06 AM
Too late now, but I would’ve just welded the nut straight to the ‘shell.
I’ve never understood why they used this type of ‘loose’ captive nut for the battery earth as they promote bad connection.
#279 dasupersprint
dasupersprint
  • 848 posts
Posted 06 November 2018 - 06:40 PM
Been fitting some pieces of the new carpet set. They are Velcro'd, as I don't want to glue them in place
#280 dasupersprint
dasupersprint
  • 848 posts
Posted 06 November 2018 - 06:41 PM
Repairing bad connections and plugging wires...
#281 dasupersprint
dasupersprint
  • 848 posts
Posted 06 November 2018 - 06:44 PM
Made a hole in the right side A post for the switch and installed door straps
#282 dasupersprint
dasupersprint
  • 848 posts
Posted 16 November 2018 - 03:00 PM
I found this!! Ouch! Repaired it
#283 dasupersprint
dasupersprint
  • 848 posts
Posted 16 November 2018 - 03:03 PM
The lower dash rail was broken in two pieces when I took it out in 2009. It's super expensive to buy a new one, so I tried to repair it. I glued the two pieces together and it worked well. I tried to hide the remaining crack by wrapping the whole piece with a vinyl piece but it didn't work out. So I sprayed lots of layers of Plasti Dip and I think it came out OK.
#284 dasupersprint
dasupersprint
  • 848 posts
Dash installed
#285 dasupersprint
dasupersprint
  • 848 posts
Posted 16 November 2018 - 03:04 PM
And heater box installed! Along with it's tubing
