Something big happened! Mini is home at last! It will be much easier to work on it from now on
Posted 08 May 2018 - 05:19 PM
Posted 10 May 2018 - 01:00 PM
It has a face now!
Posted 15 June 2018 - 01:33 PM
Hello.
I began repainting stuff and getting them back in the Mini. I refurbished the tail lights with new bulbs, screws and rubber gaskets.
Installed the handbrake lever, pedal box, steering and seats brackets.
Posted 22 June 2018 - 05:06 PM
Painted the inside of the rear bins, as they were dirty and green
Posted 22 June 2018 - 05:07 PM
Connected the handbrake, and it works!
Posted 26 June 2018 - 05:47 PM
The go pedal is in
Front seats cliping brackets
Posted 26 June 2018 - 05:48 PM
Front seatbelts, and chrome trim on the rear bins
Posted 26 June 2018 - 05:49 PM
Really nice day yesterday so I dragged the Mini outside!
Posted 26 June 2018 - 05:50 PM
I then installed the four fiberglass Sport pack arches
Posted 26 June 2018 - 05:52 PM
Posted 20 July 2018 - 01:44 PM
I sorted the rear loom and put it in place, as well with the third brake light
Posted 20 July 2018 - 01:47 PM
Don't forget you need the rubber pad underneath the handbrake cable where it goes through the body...
https://minispares.c...1A385.aspx?0402
Posted 20 July 2018 - 02:52 PM
Yep, thanks I knew about this but I think it was out of stock when I made my order, so It's still on my list. For the moment I put two layers of electrical tape under the fairlead plate
Posted 31 July 2018 - 07:16 PM
I put the fuel tanks in. Still a bit of fiddling for the left strap to fit at the right place. I need a shorter bolt for the right side straps, too.
