Canadian 1978 Mini 1000 - Long Resto
720 replies to this topic
#166 dasupersprint
dasupersprint
  • 848 posts
Posted 28 November 2016 - 07:49 PM
Meanwhile, bearings are installed in front hubs
#167 dasupersprint
dasupersprint
  • 848 posts
Posted 28 November 2016 - 07:51 PM
Bearings in rear hubs too
#168 dasupersprint
dasupersprint
  • 848 posts
Posted 28 November 2016 - 07:52 PM
New 55mm studs to accommodate spacered drums
Edited by dasupersprint, 28 November 2016 - 07:52 PM.
#169 dasupersprint
dasupersprint
  • 848 posts
New tie rod ends and locking nuts
#170 dasupersprint
dasupersprint
  • 848 posts
Posted 28 November 2016 - 07:55 PM
I tried to fit the new swivel ball joints and I found that Minispares had not supplied enough shims for them! So I dug out the old hubs and salvaged old shims. I hope I will have enough now...
Old and to be reused shims
Edited by dasupersprint, 28 November 2016 - 07:55 PM.
#171 dasupersprint
dasupersprint
  • 848 posts
Posted 06 December 2016 - 01:56 PM
I had JUST enough shims with the old ones, phew I was lucky. So the front is ready to go on the car now. It may miss some things, but the goal is just to put the Mini on its wheels for now.
#172 dasupersprint
dasupersprint
  • 848 posts
Posted 07 December 2016 - 01:17 PM
Now to the rear!
I damaged threads when dismantling, so I repaired them
#173 dasupersprint
dasupersprint
  • 848 posts
Posted 07 December 2016 - 01:19 PM
New shaft, bearing and seals with the radius arm repair kits.
And also new handbrake quadrants. This radius arm is ready to go.
So there it goes
#174 dasupersprint
dasupersprint
  • 848 posts
Posted 14 December 2016 - 01:20 PM
Right side radius arm in position, with rebuild kit installed
Nice.
#175 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 14 December 2016 - 02:05 PM
Looking really good, you have broken the back of the project once you put the welder away and get the spray gun out. Keep up the good work.
#176 pete l
pete l
  • 1,368 posts
Posted 14 December 2016 - 04:00 PM
Why did you enlarge the rear wheel arches ? I thought you only had to do the front ones for the sportspack and 13" wheels.
Edited by pete l, 14 December 2016 - 04:00 PM.
#177 dasupersprint
dasupersprint
  • 848 posts
Posted 14 December 2016 - 05:35 PM
True, you don't have to cut the rear, but you can, to give more clearance for suspension travel if you run a lowered suspension, which I will.
#178 dasupersprint
dasupersprint
  • 848 posts
Posted 14 December 2016 - 05:38 PM
Thanks mate! I still can't believe one day I will drive a complete Mini. 6 months ago I thought I would do bodywork and welding on this car for the rest of my life.
#179 dasupersprint
dasupersprint
  • 848 posts
Posted 15 December 2016 - 01:46 PM
Lots of fun last night.
Cone, Hi-Lo and knuckle joint in
#180 dasupersprint
dasupersprint
  • 848 posts
Posted 15 December 2016 - 01:50 PM
Shock. I spent too much time trying to make the top nut grab... the threaded rod could be 1mm longer it would be so much easier!
