Castor angle
Pavel
, Apr 01 2004 07:53 PM
17 replies to this topic
Posted 01 April 2004 - 07:53 PM
My car seems to tilt the wheels outwards at the top (increase positive camber) as the wheel turns in!!!
As far as I know castor must be set the other way round, so the wheels tilt into the corner, not out of it!
Firstly, what is this castor called (positive or negative)?
Secondly, is there anyway to fix it?
Posted 01 April 2004 - 08:15 PM
Basicly the bottom of the wheel is further forward than the top (the pivot points ), if it was the otherway round you would have negative castor (this can hapen if the subframe is bent and the tie-rod pushes the bottom arm back )
Posted 01 April 2004 - 08:53 PM
Well thats what i said, seems like i have negative castor, but im pretty sure my sub is straight!
Could it just be that my car has positive camber up front and it is exagerated when turning the wheels?
Posted 02 April 2004 - 07:31 AM
CASTOR and CAMBER are NOT the same.
Camber is the the angle that the wheel is tillted at from the vertical.
Castor is the angle that the wheel sits on the road compared with where the centre line of the swivel axis would be
Siggy
Siggy
Posted 02 April 2004 - 08:54 AM
yeh i know
castor increases negative camber as a wheel turns in..
on my car, it seems like the negative camber decreases as the wheel turns in, and im wondering whether this is because of negative castor or whether i just have a lot of positive camber on the front wheels
Posted 02 April 2004 - 11:32 AM
But it looks like Woody does not.
Basically if the castor is out the front end is bent. I would have thought that the drivability of it would be terrible. if it was that far out. IIRC the steering would be very easy to turn in but you would need a 6ft steering wheel to straigten it up. otr the opposite.
It sounds like there is nothing wrong, the camber angle will change on a lock
Siggy
Siggy
Posted 02 April 2004 - 11:34 AM
Drives fine, must just be me then
Posted 02 April 2004 - 01:15 PM
The moral of this story is If it an't broke don't fix it' ))))
Siggy
Siggy
Posted 03 April 2004 - 05:49 AM
Yea guys i do understand (i have certificates to prove it )but i dont have certificates in explaning it ,even your explanation Siggy seems baffling (but i know what you mean !)
In the garage i worked in until last year we had a Bear 4 wheel alignment system (lazer beams and all that )and where adjustable i could set Caster , Camber,Toe and camber and toe on the rear as well as checking set back and S.A.I or K.P.I as we used to call it .
Posted 03 April 2004 - 06:08 AM
When you completed your NVQ, if you used the 'Brooks' book, a good explenation is in the Chassis Transmission book level 3.
Siggy
Siggy
Posted 03 April 2004 - 06:17 AM
camber and castor is really much easier to explain with a picture
if you re-read woody's original explanation, it actually is correct
as they say, a picture is worth a 1000 words
Posted 03 April 2004 - 06:40 AM
re reading it, his explanation is not too good. As you say a photo is worth a 1000 words. Its phyisically impossable for the bottom of the wheel to be further forward than the top.
If you were able to draw a line throught the centre of the Kingpin or ball joints. This line would touch the ground in front of the contact area of the tyre. If you then drew a line from the top to the bottom of the tyre. the angle between the 2 is the Castor angle.
Siggy
Siggy
Posted 03 April 2004 - 09:35 AM
granted this is for RC, but the idea is the same:
What it does: Caster is the angle of the steering kingpin in relation to a vertical plane perpendicular to the ground. With the top of the kingpin angled back towards the car you have negative caster. Positive castor, with the top of the kingpin would be angled towards the front of the car, is never used. Negative castor makes the car more stable to drive in a straight line. Without it, the car would feel very twitchy, react very quickly to steering inputs and easily spin out. The more negative caster you have, the more steering you will have in high speed sections, during turn in, and the more stability you’ll have in the straights. With less caster, you’ll have more low speed steering with less stability in the turns and less steering during turn in.
Posted 03 April 2004 - 02:54 PM
It is exactly the same.
Thinking about it if you look at the front forks and wheel of a motorbike, you can see it clearly.
Sigygy
Sigygy
Posted 03 April 2004 - 07:10 PM
the other benefit of having more castor, is that it helps the steering self centre as well
