Fitting Hi-lo's Without A Compression Tool?
#31
Posted 23 April 2010 - 06:52 PM
#32
Posted 23 April 2010 - 08:57 PM
I used a screwdriver to lever the shaft through (from the bulkhead side) via hitting it with a hammer! This worked to a degree until the shaft had disappeared in to the suspension arm itself and was poking through more on the other side (towards the headlights).
But now it's just stuck there! I can't lever anymore out and i can't pull it with anything because mole grips will just ruin the thread!
Was everyones this stiff and seized?
Mike
#33
Posted 23 April 2010 - 09:01 PM
Rich
#34
Posted 23 April 2010 - 09:13 PM
I took that plate off, and the steel washer :S and mines still stuck??? There's not some other mystery washer i haven't seen is there? From what i can see, it looks like it should just slide out....but the bloody thing won't! So frustrating!
#35
Posted 23 April 2010 - 09:22 PM
It could just be that its jammed on bump stop on the other side of the mount, i pulled this side of the mount forward abit and then wiggled the pin out.
Rich
#36
Posted 23 April 2010 - 09:27 PM
what could be jammed on the bump stop? isn't the bump stop further up towards the doughnut?
Thanks Rich
#37
Posted 23 April 2010 - 09:42 PM
Good luck!
Rich
#38
Posted 23 April 2010 - 09:54 PM
theres loads pop up on ebay if yo dont want to make one, we got one with both metric and imperial threads for about £20 and it works wonders
#39
Posted 23 April 2010 - 11:02 PM
With reagrds to Adam and all others suggesting i use a compression tool, read my first post in this topic.....i don't have any threads in the cone for a compression tool to screw into, hence it would take even longer to use a tool due to the fact that i would require a new doughnut as well!
On the plus side, this will serve as proof that hi-lo's can be fitted minus the cost of a compression tool that you only use once (a bad investment)!
Once completed on this side of the car, i will do the same on the side and photograph every step and make a guide for others to use!
Mike
#40
Posted 23 April 2010 - 11:19 PM
#41
Posted 23 April 2010 - 11:30 PM
Let me know how you get on mate.
Rich
#42
Posted 24 April 2010 - 07:43 AM
Oh and p.s - if you're in need of the loan of a compressor reasonably locally PM me
Edited by wile e coyote, 24 April 2010 - 07:45 AM.
#43
Posted 24 April 2010 - 07:34 PM
only thing you need to remove for this is the wheel and the bonnet
#44
Posted 25 April 2010 - 05:12 PM
Your right, because the compression tool wasn't being used, a lot of downward pressure was being applied to the top arm....this was casuing problems somehow. So i put a trolley jack underneath the top arm with a bit of wood and jacked it up a bit! This seemed to free everything that was stuck, and with a pair of mole grips (on the non-threaded part) of the pin, i just pulled it straight out!
Job done!
Like i said, i will photograph the other side and make a guide! Because if you know how to do it, it's just as easy as using a tool (but cheaper)
