Edited by nicksuth, 06 March 2010 - 08:48 PM.
Moss Dash Switch Illumination Kit
Posted 06 March 2010 - 08:46 PM
Posted 06 March 2010 - 08:53 PM
Edited by nicksuth, 06 March 2010 - 08:58 PM.
Posted 06 March 2010 - 08:55 PM
Posted 06 March 2010 - 08:58 PM
The Moss kit is brilliant. Takes the feed from the auxillary guages (just plugs in.)
Was very easy to fit, only took me about 10 mins.
Good luck
Tom
Posted 06 March 2010 - 09:04 PM
I bought the Moss one because it was the only 5 switch one I could find. I asked Minispares and they said that they don't stock it...
Good luck
Tom
So no cutting or splicing needed then? I need to have a good look behind my dash as it's got plent of extra electrics fitted like windows, central locking, 50x Clifford alarm and immobiliser and switches/sensors all over for movement, open door, lights left on etc etc etc. (looks like multi coloured spaghetti in there !!!!)
Edited by nicksuth, 06 March 2010 - 09:04 PM.
Posted 06 March 2010 - 09:08 PM
Mine's got Remote Central Locking, no troubles there. It really doesn't take up much space
Tom
Posted 21 March 2010 - 07:07 PM
Any ideas? I'm not that fussed as it's the brake check switch as it's not one you use regular in the dark (or light for that matter)?
Edited by nicksuth, 21 March 2010 - 07:09 PM.
Posted 21 March 2010 - 07:18 PM
Although I'm sure someone who has already fitted this mod will enlighten us on the full facts.
Posted 21 March 2010 - 07:46 PM
Posted 21 March 2010 - 07:48 PM
im looking at getting one of these have you got any pictures thanks dan
Posted 21 March 2010 - 07:56 PM
ok thanks are they really easy to fit as im only 16 and not very good with electrics thanks danTried taking some pictures but even with the flash turned off the switches are not bright enough for the camera to pick up, however, they do "glow" and make hitting the right switch a lot easier
Instruction - LINKY
Posted 21 March 2010 - 08:04 PM
Instruction - LINKY
The instructions suggest it's easy but believ me, it ain't that straight forward > I suggest you get someone who's a bit more familiar with auto electrics to give you a hand.
PS - make sure you get the right kit as there is a 4 switch and 5 switch version.
Posted 21 March 2010 - 08:05 PM
ok ill think ill get the mechanic up the road to do it thanks for all advice thanksok thanks are they really easy to fit as im only 16 and not very good with electrics thanks danTried taking some pictures but even with the flash turned off the switches are not bright enough for the camera to pick up, however, they do "glow" and make hitting the right switch a lot easier
Instruction - LINKY
Posted 21 March 2010 - 08:11 PM
