Not really a problem, just a question
What is the size of a mini boot?
ill have a 7.5 gallon tank
Iv found an old suit case on ebay,it ends soon, and i cant get to my boot
its size reads as
22 inch wide
12.5inch deep
7 inch high
will it fit??
thanks guys
Boot Size
scoticus
, Mar 02 2010 10:37 PM
6 replies to this topic
Posted 02 March 2010 - 10:37 PM
Posted 02 March 2010 - 10:54 PM
Why not just go and measure your boot - Surley that would be quicker?
Posted 02 March 2010 - 10:56 PM
Read before posting
Posted 02 March 2010 - 11:17 PM
Fair point
But do you have a boot kit - the carpet covered pannels?
Posted 02 March 2010 - 11:57 PM
I believe it's 70cm (or 27.5 inches) wide by 57cm (or 22.4 inches) deep and the parcel shelf is 34cm (or 13.3 inches high). Thats the floor size by the way. Based on this information, yes the suitcase will probably fit in the boot but it depends whether you want it in a certain orientation. I'm not 100% on the depth but it's that or about 50cm (or 19.6 inches). This is at the widest point at the base. I think the angle of the bulkhead is just under 70 degrees if vertical is 90degrees if that's any use.
edited to say: These measurements are upto the edge of a standard late model fuel tank, I think that's the 7.5 gallon one.
Edited by daveholman, 03 March 2010 - 12:01 AM.
Posted 03 March 2010 - 12:12 AM
thanks guys
big help...
big help...
Posted 03 March 2010 - 07:59 AM
Don't forget that the boot tapers up toward the top due to the bulkhead and boot lid. The depth nearer the top of the boot is only approx 10" deep.
