I'm not the best at updating this, but here's the next installment. Been pushing on with the car over the past couple of weeks...
Okay set to work on finishing the front end, quite pleased bearing in mind i used non heritage panels (Except the scuttle).
I didnt have enough grips to mount all the panels first, and the weather hasnt been the best lately so i decided to get a rough idea by lining them up with the front panel and the a panels as best i could then just tacked them in place. Going to have to get a new bonnet too as mine is pretty warped in the middle.
After a lot of trial and error and some frustrating moments i managed to get them all fitted and looking like this
So that was one of the final big things that needed to get done. Another big task was to get the rear subframe built up again
Then with some help i got it mounted in fine
All going well? No.
One of the nuts inside the heelboard is too far gone, the bolt wouldnt catch and after using a tap to get the threads sorted it wouldnt tighten. So today i cut out a little section in the sill ready to fit a new nut on the back, didnt get any pictures as theres not much to look at, but finding a bolt the right size is a bit of a nuisance. This is one of the last things i need to do before it gets painted, all i have to do is get the subframe sorted, brakes bled, trim put on so i can get it MOT'd then paint!
However, i also managed to sort out a little problem on one of the subframe steadies at the drivers footwell. There was basically nothing holding the steady on with any strength, when i went to touch the head of the bolt with a screwdriver it pretty much just fell off so i decided that instead of taking the bolts out i would just cut around them and then weld straight onto the mount, making it effectively a solid mount, much sturdier than before.
After cutting around it, cleaning it a bit and adding some weld through:
I layered the sheet metal, putting a slightly thicker guage metal underneath directly onto the subframe steady to make sure it was strong enough, plug welded onto the mount. Then slighty thinner metal on top to add an extra bit of security and to finish it off. I also effectively welded in the heads of the bolts which go into the mount, there was no way you'd get a spanner on them and i didnt see the need to take them out. Not much to look at but function..
Bit of a dilema with the paint as i'm not sure what colour i want to go, i'd like to stay red but lately i've been seeing a lot of pale gray/cream cars which have really caught my eye.
If i keep it red i dont need to get the interior painted, but i love the white/cream/grey!
Anyway, hopefully have some more updates soon as i'm going to be fitting the exhaust, fuel tank back in maybe over the weekend if i can get some time so hopefully get the car running next week at some point!
Edited by dougie1142, 28 May 2011 - 02:40 AM.
