Today, i finished everything off!!
First thing i did was to re-wire the mono amp from under the passenger seat to the boot. New earth point on the rear bulkhead, rewired the ignition wire, RCA cables and 12V feed.
The amp was then screwed to the back board of the boot liner kit and all the wires were attached. The boot kit was then fitted - it looks mint.
The next thing was to line both panels with sound deadening material. It's actually quite easy to apply if anyone was wondering. You just peel off the back and stick it straight on. You need to clean the panel first of all and get off any grease or dirt. I also used a hair dryer to apply the sound deadening. It makes the sticky backing more pliable and easier to smooth onto the panel.
It was then time for the enclosures finally to be fitted, and speaker cabling to be wired in.
It looks and sounds brilliant. On first fitting, i still had the problem of one of the enclosures not quite fitting into the bin, but i fixed it later in the afternoon with a hammer. I realised the bin was bent in at the top where it shouldn't have been so a couple of knocks with the hammer and the enclosure slid in. Its a very tight fit but it just means that rattling between the box and car/panel will be at a minimum.
After fitting it all, i went for a little spin to try it all out and really crank up the volume. Apart from some minimal knocking when the bass is really up where the enclosure rattles againt the car, sound quality and clarity if brilliant. I'll put up a video tomorrow.
Photos:
First box all made up & test fitted:
Sound deadening:
First enclosure all carpeted, wired, sub fitted and in place:
Second enclosure:
Final result: (It doesn't look symmetrical because the right hand box hasn't been put in place properly)
So thats it!! About two weeks of planning, spending, fabricating and fitting and i think it looks and sounds brilliant. What does everybody else think??
The next project is to make some door bin pods for component speakers. It won't be for a while though, probably not until summer after uni finishes because i have so little money now after this little escapade. A new thread will be started when i eventually get going.
