Mini Mpi Diagnostic Plug In
7 replies to this topic
#1 paynog
paynog
    Just On Tickover
  • 9 posts
Posted 27 February 2010 - 03:58 PM
hi all
i was wandering where abouts the diagnostic plug in is for a code reader on a mini cooper 1998 mpi? as i have an idling problem that leads me to believe a sensor is faulty (coolant temp sensor) ? thanks
#2 bamby
bamby
  • 1,342 posts
  • Local Club: Fylde Mini Club
Posted 27 February 2010 - 04:59 PM
Hi there paynog - this link may help you with your question.
However can you plese post this in the correct section - it needs to be in the Mini Technical Section -Injection Mini Specific SPI/MPI
#3 R1minimagic
R1minimagic
  • 4,660 posts
Posted 27 February 2010 - 05:09 PM
There is one on the side of the pedal box next to the clutch pedal.
#4 Cooper1999
Cooper1999
  • 34 posts
Posted 01 March 2010 - 11:39 AM
hi all
Out of interest, what fault code reader are you using?
#5 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 01 March 2010 - 12:02 PM
as minimagic said its above the cluch pedal box under the dash rail think its a obdII
#6 mykweb
mykweb
  • 543 posts
  • Local Club: does here count :)
Posted 01 March 2010 - 12:40 PM
hi all
Yes its an ODB 2 connector
If your temp sensor is faulty you will be getting High or Low readings on the Water temp gauge.
Usually if your getting idling issues this is caused by the ICV (blue plug) to the left of the throttle body, located on the inlet manifold.
Easy way to fix it is to take it off and give it a good clean with petrol or cleaning solution.
Other issue could be Inlet Air Temp sensor (IAT) green plug located on the inlet manifold. This works in conjuction with the ICV and the Water Temp Sensor to determin the correct ammount of fuel and air at idle.
Also when does the car idle funny? Is it when its cold or warm?
Mike
#7 icklemini
icklemini
  • 2,982 posts
Posted 02 March 2010 - 10:46 AM
Its the 16pin connector - but its not OBD compliant..
#8 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 23 March 2010 - 05:01 PM
I have a cheapo ODB2 Reader off ebay works fine on my mpi 98
