Wheel Arch Liners!
#16
Posted 23 February 2010 - 11:05 AM
#17
Posted 23 February 2010 - 12:09 PM
Agreed, they are cheap compared to a new front end, scuttles, paint etc.I have fitted both types to a lot of of my minis. Camlo don't exist anymore as already stated. The derek's mini type are made so that they will fit round nose and clubman fronts. I would recommend them to anyone who wants to preserve their front end. IMO they are worth the £65 they ask for them.
Care should be taken with the mounting screw/rivets etc as these can be there own source of rust point.
Edited by mk3 Cooper S, 23 February 2010 - 12:17 PM.
#18
Posted 23 February 2010 - 12:17 PM
And bunch1980, your picture is amazing!!
#19
Posted 23 February 2010 - 12:19 PM
LOL
#20
Posted 23 February 2010 - 12:22 PM
They do appear expensive for formed sheets of plastic but it's all about prevension or cure. The prevension is cheaper than the cure.
They are only any good if you front end is mainly rust free to start with though - they arn't a miracle cure.
Edited by mk3 Cooper S, 23 February 2010 - 12:22 PM.
#21
Posted 23 February 2010 - 12:34 PM
#22
Posted 27 February 2010 - 02:01 PM
I cut them down a bit and fitted them to my mini, they seriously help the wing seams from rusting, HIGHLY recommended!!
#23
Posted 27 February 2010 - 05:16 PM
heres how the look fitted, oh and all the yellow goo is waxoil
#24
Posted 09 February 2011 - 04:30 PM
Can I see some more photos from people?
#25
Posted 09 February 2011 - 05:50 PM
#26
Posted 09 February 2011 - 05:53 PM
They are fairly simple to fit and I haven't found any issues with them being a dirt or moisture trap personally. They are so designed to deflect dirt & moisture away and having seen them up close & fitted them, I can't really see how that could happen. Even if your wings, scuttle & front panel etc are far from perfect, they will still stop water, salt & grit from being blasted up into the usual places, so they are far better than nothing at all. They also have the added bonus of protecting the waxoyl you have sprayed under there from being washed away, so fitting them to corroded panels is still worthwhile as it certainly slows down the rot.
My only criticism is that if you have to do a lot of modification to the nearside one, if you have later model that has the auxillary fan fitted in the nearside inner wing.
Heres Mine:
#27
Posted 09 February 2011 - 06:01 PM
#28
Posted 09 February 2011 - 06:09 PM
But £80 ! shame we cant do a group buy on them and get them cheaper.
#29
Posted 09 February 2011 - 06:39 PM
Maybe we could get them cheaper, hmm, might be worth an email.
#30
Posted 10 February 2011 - 10:24 AM
