Micamin
51 replies to this topic
#1 flying banana
flying banana
  • 84 posts
Posted 21 February 2010 - 12:08 PM
hi all,
its about time that i started a thred about my MICAMIN
(all the credit to this build will go to BIGCHIEF it been an inspiration its his fault)
any way hear goes.
ive had this mk2 cooper for about 15 years and used and abused it doing 12 car rallys
so its had a hard life,after the last engine build which cost me lottttts then i had a
problem with oil feed which fu**ed the engine up in a big way i said never again
to spend so much on an A series engine.
it was 1340, 98bhp stage 4 11stud head,rimflow valves,full roller rockers,split webbers,
643 rallycam,adjustable timing,centre main strap,cross drilled/nitrided,staight cut drops,
3syn straight cut box,crosspin diff.it sounded fu**ing fantastic.
history lesson over.
NOW
after reading bigchiefs build i was bitten by the micramin bug THANKS
then started to look for a doner
and this was it hit by a bus, but engine has only done 9000 miles £180 not bad bargain,
and then it started oh dear
with the making of subframe and trying to put engine in this was the hardest part
due to me having a latter engine and a bigger gearbox which ment i had to re make my
plan of copying bigchiefs subframe (you got it so easy bigchief lol)
but onwords and up words
#2 flying banana
flying banana
  • 84 posts
Posted 21 February 2010 - 12:19 PM
next subframe in car and a bit of cutting
the inlet made the most problems
and an inside picture
and this is where i am now
#3 flying banana
flying banana
  • 84 posts
Posted 21 February 2010 - 12:20 PM
that it for now i will be back
and if any of you wonderd why im putting such a small engine in my mini and not a
vtec/or bigger. its because of got a bigger toy its this
thanks see you soon andy
Edited by flying banana, 21 February 2010 - 12:21 PM.
#4 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 21 February 2010 - 01:13 PM
how will you be mounting the clutch master cylinder if you dont mind me asking? as i see you had to cut out the section where the original type master cylinder would be?
#5 flying banana
flying banana
  • 84 posts
Posted 21 February 2010 - 07:31 PM
hi mate i will post up picture tomorow but it is now done by cluch cable simple really. i have run the cable through
the speedo cut out and made a cut out in parcel shelf
andy
#6 evansisgreat
evansisgreat
  • 1,141 posts
  • Local Club: Not yet
Posted 21 February 2010 - 08:22 PM
Looking good all mounted up, how close are you to running it? What kind of power you aiming for?
#7 less is more
less is more
  • 172 posts
  • Local Club: NONE
Posted 22 February 2010 - 11:01 PM
Must admit Bigchiefs thread inspired me and this one looks cool, can't see why more people havn't done this conversion.
The only thing that has put me off is the new IVA/SVA minis seem to be getting hit quite hard soon, are you going to be putting this on the road? if so are you worried about this new ruling **it
Andy
#8 flying banana
flying banana
  • 84 posts
Posted 23 February 2010 - 12:29 PM
some pictures of how i done my clutch
i hope this helps
and some of my alternator
thats it for now
andy
#9 flying banana
flying banana
  • 84 posts
Posted 23 February 2010 - 12:32 PM
Andy
tell me more? i did not know about about this any one shed some light on it :lol:
#10 jimbob69
jimbob69
  • 30 posts
Posted 25 February 2010 - 04:02 PM
bulkhead mods and IVA was discussed here
http://www.theminifo...howtopic=149421
Jim
#11 evansisgreat
evansisgreat
  • 1,141 posts
Posted 04 March 2010 - 01:15 PM
There's something I really want to know about this conversion. How heavy is the clutch? I'm looking to make my mini my comfortable, even luxurious so if I'm going to all the trouble of a conversion I'd like a lighter clutch pedal.
edit: spelling
Edited by evansisgreat, 04 March 2010 - 01:16 PM.
#12 Artstu
Artstu
  • 837 posts
Posted 04 March 2010 - 02:19 PM
I can tell you that the clutch on a standard Micra is super light, so I imagine it will be very similar on a mini set-up
#13 richardsoniscool
richardsoniscool
  • 629 posts
  • Local Club: Bury Mini Club
Posted 04 March 2010 - 06:22 PM
yeah my mates got one - very light.
#14 bigchief3679
bigchief3679
  • 228 posts
  • Local Club: trinimini
Posted 07 March 2010 - 02:38 AM
X3...........extremely light. only ur big toe is required. seriously
#15 gregh55
gregh55
  • 1,706 posts
  • Local Club: naaa
Posted 07 March 2010 - 02:41 AM
>_< how have i missed this! amazing work, ill be keeping an eye on this
