200bhp Supercharged?
#91
Posted 26 June 2010 - 03:05 PM
#92
Posted 29 June 2010 - 04:11 PM
hes also making me a new one off cam as i dont need an emissions test as such as my car is rather old.also he has produced a twin throttle body set up now as well.
car made 160-161 at vmax stuart would be able to verify this.on standard bottom end with a head from himself which is worked more than the normal ones.and hes also mapped it for superunleaded and i cant use normal unleaded in it.
but in my rebuild now will have twin throttle bodys and new cam which should hopefully see a bit of improvement.and im upping the compression ratio a little bit so i dont have to raise boost to keep the charger as efficient as possible all in the quest for a bit more power.
#93
Posted 01 July 2010 - 02:58 PM
thanksthe injectors are put into the supercharger itself just under the intake pipe.and i think it ge mixed up in the charger itself.sort of like a half wet set up from what i can see the injectors put fulein just behind the change from first and second rotor..best person to ask is stuart at vmax scart.
