200bhp Supercharged?
92 replies to this topic
#31 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 02 March 2010 - 07:06 PM
but the fuel consumption and reliabilty would be alot worse on the supercharged which is not ideal on a road car either...
im not trying to say there awefull just comparing to a another high spec engine, i still think the price is much to exessive for the benfits on a supercharged lump?...
Edited by rick.spi, 02 March 2010 - 07:07 PM.
#32 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 02 March 2010 - 07:34 PM
has anyone considered a supercharged turbo???
#33 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 03 March 2010 - 11:26 AM
started considering it yeti. my question still comes back to a blow through supercharger what are its limits
#34 Sam Walters
Sam Walters
  • 2,765 posts
Posted 03 March 2010 - 11:32 PM
To get big power from a super charger your going to have to run a big cam for starters as well as the fabrication work involved for a blow through setup.
A GT17 turbo seems to a good weapon at this moment in time. i mean over 100 lbs/ft @ 2800 rpm.
Image pinched from turbominis.co.uk
#35 Prawn
Prawn
  • 938 posts
Posted 04 March 2010 - 08:06 AM
that's a pretty epic graph isn't it! I wish robert would give away some details about his cam!
From memory, I believe robert said that the blue curve is at 12psi, red curve is at 15psi, and the green curve is at 16psi. running 16 degrees timing with no IC fan. if I get anywhere near that at all I'll be over the moon!
#36 mini.cooper998
mini.cooper998
  • 685 posts
Posted 04 March 2010 - 12:44 PM
surely cams are very specific for turbo supercharged engines due to the overlap you down want to be blowing the charge streight through after all.
what engine spec is he running to achieve that kind of power becasue thats high.
#37 mini13
mini13
  • 3,810 posts
Posted 04 March 2010 - 05:30 PM
lightly (home) ported head, and a gt17 turbo and the cam mentioned above, the rest is fairly standard.
#38 MarkGTT
MarkGTT
  • 528 posts
Posted 04 March 2010 - 06:08 PM
heres mine for comparason on a T3, although i dont get much lag i think the boost is more efficiant with a GT17.
#39 Wil_h
Wil_h
  • 3,244 posts
Posted 04 March 2010 - 06:59 PM
Yes, the compressor (and importantly) the turbine are very efficient on the GT17. I gaind 15bhp for no extra boost fitting one.
#40 [email protected]
[email protected]
  • 152 posts
Posted 04 March 2010 - 07:49 PM
Out of interest, how readily available are GT17's and manifolds for them etc?
#41 MarkGTT
MarkGTT
  • 528 posts
Posted 04 March 2010 - 08:15 PM
buy a new one for arround £400 - £500 most the second hand ones seem to be scrap.. the manifold need to be a custom job or you need an adaptor plate for the metro turbo manifold.
#42 mini.cooper998
mini.cooper998
  • 685 posts
Posted 04 March 2010 - 09:11 PM
what cars and year / model was the GT17 fitted too
#43 MarkGTT
MarkGTT
  • 528 posts
Posted 04 March 2010 - 09:45 PM
GT1752 - Saab 9-5 / 9-3 think it is 1997 on, you will have to search the web.
#44 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 04 March 2010 - 09:46 PM
i'd say a gt17's as big as you want to go on a road car, mines the next one up a gt20 and is about the same lag wise as a std t3 but a lot more efficient.
i've still got a few little things left to tweak and maybe a cam change to nudge the boost threshold a bit lower if possible. i think upping my rev limit will release a few extra banana's up top too.
#45 Wil_h
Wil_h
  • 3,244 posts
Posted 04 March 2010 - 10:08 PM
Go to www.crturbos.co.uk and plug GT1752 into the search to see what they are fitted to. CR turbos will rebuild a 17 for £300.
