This means i will probs end up having to stick with my 998
if i have to change a wing due to rust does that class as a modification?
engine only carries 1 point, you start off with 12 and need 8
ACE say
it is necessary to differentiate between modification and repair. Any repair process that is in line with manufacturer's recommendations and that returns the structure to its original specification would not be considered to be a modification.
you can replace a wing with out worry
