Weld Up Those Bulkheads Or Face An Iva Test
356 replies to this topic
#256 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 04 November 2010 - 06:08 AM
http://www.direct.go...cate/DG_4022054
Changes you need to update
You’ll need to tell the Driver and Vehicle Licensing Agency (DVLA) about the following changes to your vehicle:
* colour
* engine
* cylinder capacity
* fuel type (propulsion)
* replacing or modifying the chassis/monocoque bodyshell
* seating capacity
* weight of a goods vehicle
not seen that bit before
#257 Sir Cheat
Sir Cheat
  • 1,171 posts
Posted 04 November 2010 - 09:52 AM
:P :thumbsup:
#258 clubmanvan
clubmanvan
  • 28 posts
Posted 22 January 2011 - 12:02 AM
If you go under 8 points or if you modify the monocoque.
What is classed as a modification to the monocoque may be the grey area, I guess?
I mean, if you trim your front arches to fit 13" wheels, you're going to be OK.
If you chop out a part of your cross member to fit a turbo box, they're going to want to check out what you've done.
There are definite rules, but as said earlier, rules are down to different peoples' interpretations.
but it clearly states that cars 10 years or younger will not req the test therefore if your modifications are satisfactory for mot standards then you fine
#259 Ethel
  • 26,786 posts
Posted 22 January 2011 - 12:40 AM
The way I read it is your car ceases to be the one it was and becomes a newly built one if you excite the dvla enough to make you have an IVA.
The ten years is aimed at unmolested vehicles that can prove their age, on the assumption they were built under comparable regulations to the UK - imported 2nd hand production cars. - perhaps I'm muddling your point with the BIVA/IVA differences. I think my first point still stands and it's more likely to be a free pass for all those MGB's 'n E types those awfully decent chaps in the foreign office who might want to bring back when they finish their stint for a commonwealth consulate
#260 clubmanvan
clubmanvan
  • 28 posts
Posted 22 January 2011 - 11:03 AM
yes agreed however it can be taking that if you start "modifying" a car over 10 years old then it will not req a check?
qoute "when a car does NOT require a IVA check = when is 10 years old or older 25 years for a commercial."
loop hole in a grey area perhaps?
just thought it would help you guys at a vosa check etc
#261 Ethel
  • 26,786 posts
Posted 22 January 2011 - 11:05 AM
Who knows, but since the dvla will be judge & jury I wouldn't rely on it.
#262 garrett3
garrett3
  • 1,412 posts
Posted 22 January 2011 - 11:50 AM
What it means is that if the car was modified to an extent as to lose its original identity (radically altered) over ten years ago, notified to DVLA and you can proove that and it has had no changes since and has been insured and mot'd as such then you may not be required to have an IVA test.
However they can still enforce a Q registration on that vehicle.
Your car can be 30 years old and if you modify it and you lose enough points of the original car OR you modify the chassis/monocoque structure your car WILL be required to undertake an IVA.
I hope this clears things up.
There are no loopholes to exploit, they are running things very strictly now.
Edited by garrett3, 27 January 2011 - 01:03 AM.
#263 clubmanvan
clubmanvan
  • 28 posts
Posted 24 January 2011 - 05:47 PM
What it means is that if the car was modified over ten years ago and you can proove that and it has had no changes since and has been insured and mot'd as such then you will not be required to have an IVA test.
no clearly states a iva check is NOT required on a car (not modifications) 10 years old or older (not that the mods were done 10 years ago)
just to let you know i am not in need of a check i just seen the length of this topic and seen many failed to pic up on it, just thought i would draw your attention to it
also its 25 year old for commercials
#264 mini-geek
mini-geek
  • 1,169 posts
Posted 24 January 2011 - 05:57 PM
I'd still haven't seen a car that has fallen foul of the IVA yet..... Has anyone?
#265 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 24 January 2011 - 06:23 PM
only landrovers
#266 mini-geek
mini-geek
  • 1,169 posts
Posted 24 January 2011 - 06:26 PM
What are they doing to them to cause problems as they are separate chassis so you'd have to do a lot on them to need an IVA
#267 samsfern
samsfern
  • 5,243 posts
Posted 24 January 2011 - 06:34 PM
its not going to stop me putting a turbo box in my minis bulkhead. ill still do it without even thinking of this stupid iva test, that everyone seems to be so keen on having done.
#268 Broomer
Broomer
  • 1,771 posts
Posted 24 January 2011 - 06:37 PM
Watch out the IVA police will come get you while you sleep.
#269 samsfern
samsfern
  • 5,243 posts
Posted 24 January 2011 - 06:40 PM
let them, im not one to be woken up :)
Edited by samsfern, 24 January 2011 - 06:41 PM.
#270 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 24 January 2011 - 06:50 PM
modern range rover chassis with a old land rover body and log book
