I'm going to be retaining the fixed front end and actually intend to weld in re-shaped lower inner wings which clear the subframe. It's one of the main reasons I need to know what is classed as the original suspension, steering, etc. I'm retaining rubber springs all round and the rear will be pretty much stock except HiLo's and adjustable dampers. The front uses Mini top arms, hubs, etc but with HiLo's, rose jointed bottom arms and tie bars and uprated dampers (it would be downright dangerous to use standard parts here with the intended power output!)
Steering would be all standard if it includes just the rack, column and steering arms on the hubs (hubs are Mini but non-standard for the car as it had drums originally - again it would be dangerous without the upgrade to discs).
I could build a car which (assuming my minor inner wing mods will allow the shell to retain the 5 points) will get a total of 9 points by using standard suspension and brake parts but I'd never drive it because it would most likely kill me and possibly others in short order!
JR
