Headlights Not Working
Posted 14 February 2010 - 11:28 AM
I put a post on a few weeks ago about the headlights not working on my mini, since then i'm still having the same problem,
All the lights work expect for the headlights and the rear lights on the same switch so the indicators work the brake lights work and hazards but i can't get the main lights to work.
This is what i have tried so far,
Fuses under bonnet
Battery
Chased wires
And i'm yet to have any joy, what i think is next is the button it'self but it look quite complicated for a novice like myself, i would appricate any advice if anyone has come across this problem before?
Alex
Posted 14 February 2010 - 11:44 AM
What works:
tail lights (including no plate illum)?
front sidelights, ignition off?
front sidelights, ignition on?
dash illumination?
dipped beam?
main beam?
main beam flasher?
Posted 14 February 2010 - 11:52 AM
Posted 14 February 2010 - 11:59 AM
[quote name='Ethel' date='Feb 14 2010, 11:52 AM' post='1732635']
You should bring up the old topic so we can see what's already been tried.
What works:
tail lights (including no plate illum)? not working inc plate
front sidelights, ignition off? no
front sidelights, ignition on? no
dash illumination? no
dipped beam? no
main beam? no
main beam flasher? yes but won't click on?
Any ideas?
Posted 14 February 2010 - 12:18 PM
Pull the switch from the panel. There's only 3 wires on the connector block: bridge brown to red and the side/tail & dash should light, bridge brown to blue and the headlights should work.
Posted 14 February 2010 - 12:19 PM
I'm been an absolute novice here but the fuse box i've looked at is under the bonnet is there another one that might control the switches that i don't know about?
Posted 14 February 2010 - 12:31 PM
It's the only place all the circuits you mention come together. It really has to be the switch or the brown wire supplying it.
Posted 15 February 2010 - 09:36 PM
Posted 29 November 2010 - 06:49 AM
We are having the same problem on a 94 mini 35
Posted 29 March 2012 - 04:26 PM
Dan's advice about the rocker switch fits. It's a fairly common fault. Pull the switch from the panel. There's only 3 wires on the connector block: bridge brown to red and the side/tail & dash should light, bridge brown to blue and the headlights should work.
I know this is a really old thread but the problem is still current for me, if bridging the wires helps is it a faulty switch?
Posted 14 August 2017 - 07:22 PM
