Judder Under Braking :s
15 replies to this topic
#1 Beddo88
Beddo88
  • 253 posts
  • Local Club: not yet..
Posted 12 February 2010 - 12:57 PM
Simple question, i'm getting a fair bit of judder under heavy braking. Its a perfectly standard 88 city E, and the juddering stops when the brakes are released. Have checked the bearings for movement and they seem fine. Any ideas?
Could it be the ABS kicking in? :P
Cheers, Dan
#2 mike.
mike.
  • 6,176 posts
Posted 12 February 2010 - 01:04 PM
First thing to check is your wheel nuts. If they're loose they'll let the wheel wobble under braking force.
#3 slyoldfox2001
slyoldfox2001
  • 2,936 posts
Posted 12 February 2010 - 01:13 PM
it should have 8.4" brake discs fitted - if so theres a chance they might be warpped.
classic minis dont have abs :0)
#4 Elfie
Elfie
  • 608 posts
  • Local Club: Teeside Yesteryear Motor Club
Posted 12 February 2010 - 02:37 PM
Check for play in the ball joints, I had to re-shim mine to stop it but you might get away with a good greasing of the old nipples
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 12 February 2010 - 02:43 PM
More than likely warped discs......
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 February 2010 - 02:45 PM
Another vote for warped disks...
Easy to check, jack up front of car, remove road wheel and spin, you be able to see the runout on the disk against the caliper
Edited by Guess-Works.com, 12 February 2010 - 02:46 PM.
#7 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 12 February 2010 - 02:54 PM
Quickly hijacking...
Urm what cause's warped disks apart from heat...age etc?
#8 Dolly 89
Dolly 89
    Previously known as suzzy 273
  • 1,366 posts
  • Local Club: Humberside moc
Posted 12 February 2010 - 03:46 PM
will be warped discs i should think had the same problem on mine got new discs and pads and they where fine again the funny thing was the pads looked nearly new and the discs looked good aswell but made loads of difference no judder under braking now
#9 captainjack15
captainjack15
  • 3,925 posts
Posted 12 February 2010 - 03:52 PM
I'm saying warped discs.
I replaced my brakes last weekend after they had warped discs. Annoying I tell you :P
#10 Beddo88
Beddo88
  • 253 posts
Posted 12 February 2010 - 04:44 PM
The ABS bit was a joke :)
It does have the 8.4" discs, sorry forgot to mention.
What can cause a disc to warp?
I've replaced them all probably 2000 miles ago (the old ones were VERY worn) so looks good for checking those then. What is the best way to bed new discs in so that they don't warp? (bearing in mind it has to be done legally and in a mini with literally 2 dog powers)
#11 mickyh
mickyh
  • 391 posts
Posted 12 February 2010 - 04:45 PM
probabley warped disks, i no this sound stupid but check your flange bolts when i was breaking heavy mine done this and was ok when not breaking then after my flange bolts sheered off and the brakes locked up so just a thought.
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 February 2010 - 05:19 PM
Drive sensibly, don't do any unnecessary hard braking, and don't ride the brakes...
This is more to get the pads bedded in that the disks...
#13 shedonwheels
shedonwheels
  • 821 posts
Posted 12 February 2010 - 09:48 PM
Sorry to hijack this but as above what can cause warped discs? Could it poss be very very hard braking eg emergency stop from high speed? :)
Edited by shedonwheels, 12 February 2010 - 09:57 PM.
#14 mini13
mini13
  • 3,810 posts
Posted 12 February 2010 - 09:50 PM
what discs did you buy?
cheap ones tend to warp more easily.
#15 shedonwheels
shedonwheels
  • 821 posts
Posted 12 February 2010 - 09:57 PM
Well the original poster has standard factory discs, as do I. So the cause? Heat?
