I Think I May Have Burnt A Valve
Posted 08 February 2010 - 11:49 AM
Cheers for any help in advance
Posted 08 February 2010 - 12:20 PM
The comment on being very low on power suggests more then one cylinder is having a problem though, what does the dizzy look like? is the timing still about right?
Dave
Posted 08 February 2010 - 12:21 PM
Lastly, even if it is a valve or hear issue, don't worry too much, it's not too major a job to change a head on a mini, or re-lap valves, (in fact doing valves can be quite therapeutic).
Dave
Posted 08 February 2010 - 12:34 PM
Posted 08 February 2010 - 01:51 PM
Posted 08 February 2010 - 02:47 PM
Posted 08 February 2010 - 03:39 PM
Posted 08 February 2010 - 04:09 PM
Check the manifold gasket for leaks.
Posted 08 February 2010 - 04:38 PM
was thinking that. as well fits with the not being able to rev as well.Air leak causing lean running.
Posted 08 February 2010 - 05:11 PM
dave
Posted 09 February 2010 - 01:50 PM
Posted 09 February 2010 - 02:10 PM
Posted 09 February 2010 - 02:51 PM
With the car running at idle ger some wd40 or simular and spray it around the manifold to head joint and the nmanifild to carb joint,
Check to see if the tone of the engine changes.
Posted 09 February 2010 - 03:28 PM
Also would running unleaded on a 86' mini cause a burnt valve when did they change the heads to unleaded?
if the head is a leaded - non-cnverted item then over a long period of time yes a valve can burn out.
Sounds like you need to do the above test to elliminate any air leaks, and if not then it's time the whip the head off and inspect again.
Posted 09 February 2010 - 05:10 PM
Worth doing a compression test before you whip the head off IMOAlso would running unleaded on a 86' mini cause a burnt valve when did they change the heads to unleaded?
