Metro Hubs
Posted 08 February 2010 - 12:31 AM
just got a couple of questions i know the bearings are a different design to that of the mini ones but do they use the same cv joints as a mini and can mini drive flanges be used also.
Posted 08 February 2010 - 12:53 AM
Posted 08 February 2010 - 12:57 AM
Posted 08 February 2010 - 01:22 AM
An acquaintance of mine on another forum was asking about Metro front end parts on his Clubman. I remembered that using Metro components affected the suspension geometry. John, can you elaborate a bit on what it affects?
yes they do affect the geometry but as i understand it if you fit fullt adjustable bottom arms and tie bars the caster / camber angles can sorted out to solve the problems which the metro hubs can give you.
i think you are also meant to use the arm that connects to the track rod end of the metro hub to aid in the set up.
correct me if i'm wrong
Posted 08 February 2010 - 02:33 AM
I have driven Mini suspension with Metro hubs - it was actually pretty good.
Posted 08 February 2010 - 10:43 AM
The long and short of it is, a full set up suspension with metro hubs will never be as good as a full setup suspension with Mini hubs, and a badly set up system will be like a shopping trolley, and considerably worse than a std mini setup.
Posted 08 February 2010 - 09:22 PM
For the advantage of one fit ball joints, there is no advantage to using metro hubs vs mini hubs, yes you can dial out most of the geometry issues with an adjustable suspension kit, but the one thing you can't change is the top arm which will always be the brunt of the problem. I believe there is also a problem introduced with the ackerman angle ( even when using mini steering arms ) because of the relationship between where the arm attaches to the hub in relation to the top ball joint...
what are the problems with the top arms is the angle they sit at in relation to the ball joint?
i was under the impression to use metro steering arms
Posted 08 February 2010 - 09:36 PM
Posted 08 February 2010 - 10:22 PM
Posted 08 February 2010 - 11:18 PM
Posted 09 February 2010 - 07:19 PM
If you are willing to spend the time seting the suspension up properly, and understanding what is going on with the geometry the metro hubs can offer a better setup that mini hubs, especially on 13" wheels.
Posted 04 March 2010 - 01:51 PM
cheers
Posted 04 March 2010 - 05:27 PM
the taper on the after 84 ones is larger and will not engage far enough into the mini arms, and is likely to break.
also while on the subject, rover was actually looking at homlogating the metro hubs for the MPI rally minis.... must have been a reason...
Posted 04 March 2010 - 06:46 PM
Posted 04 March 2010 - 06:55 PM
you need the smaller pre 1984 joints.
