![Photo](https://secure.gravatar.com/avatar/c003e32429f8bb1310a243bf975da713?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Bonnet Pins
Posted 07 February 2010 - 01:15 PM
I have just bought some bonnet pins from mini sport as my current bonnet does not latch down properly.
She is going for a full respray/restoration in the summer so in the meantime I thought I would use bonnet pins to keep it down.
Only problem is...I have no idea how to fit them.
Any ideas?
Thanks.
Posted 07 February 2010 - 01:22 PM
You need to put little plates in the corner to fix them.
Like so.
![Posted Image](http://i673.photobucket.com/albums/vv93/AndxLearn/DSC00045.jpg)
![Posted Image](http://i673.photobucket.com/albums/vv93/AndxLearn/DSC00043.jpg)
pictures stolen from ScottyBoi lol.
Posted 07 February 2010 - 01:51 PM
Hey mate. I'm fitting them to mine when the front's been redone.
Like so.
Hey
Thank you so much for the quick response
I assume your bonnet opens the other way, so can i put the plates you showed at the other end of the engine bay (near the grill) to fix them?
Posted 07 February 2010 - 02:00 PM
Like so.
Hey
Yes that correct. What I plan on doing with mine is having 4 plates in each corner and then 4 pins. So I can remove the bonnet completely.
Posted 07 February 2010 - 02:01 PM
Posted 08 February 2010 - 05:44 PM
Posted 08 February 2010 - 07:53 PM
![:)](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/oompf.gif)
Emma :
Remove Standard bonnet hinges (if you are fitting 4 pins rather than 2), they are a pain to remove and really tricky to get a spanner and socket on...
then start by making the plates for the bonnet pins to bolt on to.
i've used about 1.5mm thick scrap metal.
Mark on the car where you want the plate to go, i've put mine at 10cm from the corner at the top, and 12cm from the corner at the bottom
Then Mark on the Metal where you want to cut it, remember to leave a overhang to go behind the bonnet gutter to make it a bit stronger
Remove all the paint to allow you to weld it in and the paint on the body to give the welder something to earth to!!
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0202.jpg)
Then Weld in, weld in small sections at a time to avoid burning the paint in the wings/scuttle etc, and take care to move away any wiring etc which could be damaged by the heat
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0203.jpg)
Then trail fit the bonnet and make any adjustments that are needed, if you are using the original bonnet, grind off the old hinge mounts and remove the old spring etc
then put some masking tape in each corner of the bonnet, and mark on the wings and scuttle where the supports are for the pins, then transfer this mark over to the bonnet,
then decide where you want the pins to sit on the bonnet the best way to do this is to get the metal plate for the pins, which bolts to the bonnet and position in the place you want it, then use a tape measure to get both side the same... and remember the chrome trim which will take up quite a bit of space on the front pins
Mark the centre of the hole on the bonnet on the masking tape and DRILL - start off with a small hole and then drill out to the size of the pin
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0207.jpg)
if you are using a stanard bonnet you will also have to drill through the inner skin aswell as the outer
once the hole for the pin is drilled, take a punch and punch the supports underneath where they need to be drilled, and drill
loosely bolt the pins in, and roughly adjust them to the right height
then with the pins in place, put the metal plates on the bonnet where you want them and take the drill and drill the bonnet for the bolts, put a bolt in the hole you have drilled to keep the plate in the same place and drill out the rest
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0208.jpg)
then with all the holes drilled
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0209.jpg)
bolt in the plates
paint the bare metal on and around the new supports
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0210.jpg)
and refit the bonnet
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0212.jpg)
![Posted Image](http://i679.photobucket.com/albums/vv156/emalee404/Image0211.jpg)
job done
Posted 08 February 2010 - 07:56 PM
Posted 08 February 2010 - 08:32 PM
You beat me too it Jon..
If you need any better pictures just drop me a PM!
![:)](https://www.theminiforum.co.uk/forums/public/style_emoticons/default/smile.png)
Posted 08 February 2010 - 09:03 PM
Haha!
HAHA yea hope you don't mind me using your pictures. I used them to explain to my dad what I needed to do so I could use the bonnet pins. Just need to get my own sorted now. Just waitng for my fiberglass mk1 bonnet.
Posted 08 February 2010 - 09:07 PM
Nah not at all mate... If you need anymore pictures just ask..
They will look good on a MK1 Fiberglass
