No Spark
Posted 06 February 2010 - 12:26 PM
The engine is not original, after doing a search of the engine number it is a A+ 998cc.
Posted 06 February 2010 - 02:39 PM
Posted 06 February 2010 - 04:34 PM
Posted 06 February 2010 - 04:47 PM
Very unlikely to be the coil - they are very reliable. Look at points/condenser/rotor arm/dizzy cap/ HT leads pretty much in that order. AFTER - checking there is a voltage getting to the coil - and a lead going from the other terminal on the coil over to the dizzy.
this is partially wrong advice, with some good points added to it. if the ignition has been left on for a considerable lentgh of time then the coil can become damaged and stop working.
if you have no spark from your coil, then you need to check the low tension side of your ignition system.
just a quick reminder of how the ignition system works, the low tension side is built up of the coil, points, condensor, the points create an open circuit in the system creating the HT spark.
the HT side is made up of the coil output, king lead to the dizzy, rotor arm in the dizzy, spark plug leads, and then of course the spark plugs.
when the points inside the dizzy are closed the circuit is closed, a charge is then built up in the coil, and as soon as the points open the spark will travel from the coil along the king lead, into and then through the dizzy to the spark plugs, if the points do not open or stay open, then the circuit will not create the spark in the coil.
a simple test which i teach is to get a test lamp, ( a bulb with 2 wires on it) connect one end to a good earth point on the engine.
dosconnect the lead going into the dizzy.
turn the ignition on, and then see if you have power at the + side of the coil. if you don't then you have an open circuit in the wire from the ignition switch to the coil.
if the light comes on, then check the output - side of the coil. if the light fails to come on then the coil needs to be replaced.
then check the wire from the coil the the dizzy, where you disconnected it. again if the light fails to come on then you have an open circuit in that wire, change it.
if you have power at this lead then the fault is in the dizzy.
check the points are opening, check that the points have not been fitted wrong,(the wires going onto the points could be touching the base plate, this will create an earth before it should)
hope this helps
Posted 06 February 2010 - 04:57 PM
Cowboy has given you some good advice on how to troubleshoot this. If you want to read about this, I have a similar document that will hopefully give you some additional information. The PDF in the link below is my attempt to explain how the ignition works and then take you step by step through some tests to find what's wrong. If you have a good understanding of how the ignition system works, finding faults is a lot easier.
http://home.mindspri...tsIgnitions.pdf
Posted 07 February 2010 - 10:30 AM
Posted 08 February 2010 - 07:15 PM
Both Roy and Cowboy have given you good advice. I agree with Roy that the coil is unlikely to have failed. Yes, they do fail but people often blame them prematurely without diagnosing the system fully. You are likely to hear people say things like "Oh yeah, my coil went bad. I replaced it along with my points, plugs, condenser, cap and rotor and it fired right up". When you shotgun the repairs by replacing everything at once you can't determine which component really was at fault.
This guide is very useful, however does the same apply to my mini, which is possitivly earthed?
Posted 08 February 2010 - 07:20 PM
On positive earth cars the original coils were marked SW and CB (for ignition switch and contact breaker). The coil SW terminal received the power from the ignition switch and the CB terminal received the white/black wire that goes off to the distributor. When you have such an old coil connected to a car which has been converted to negative earth, these two connections are supposed to be swapped (SW gets the white/black and CB gets white from the switch on negative earth).
Posted 08 February 2010 - 07:37 PM
Posted 09 February 2010 - 05:07 PM
I have checked the coil primary resistance and that read 1.3 ohms, and the secondary resistance is 5.2 K omhs
Do you think these readings look ok, looking at the document above they seem a little low?
Posted 09 February 2010 - 05:09 PM
Posted 09 February 2010 - 05:50 PM
Posted 09 February 2010 - 06:08 PM
The age of the engine isn't really relevant to what type of coil is fitted. The ignition wiring in this case in non ballasted and so the ignition system must be run as non ballasted whatever the engine had originally, unless you want to add a ballast system. If there is only one wire to the coil + terminal and it's plain white delivering 12v, it's non ballasted ignition (unless it's a Lucas electronic dizzy).
Posted 09 February 2010 - 08:13 PM
Posted 02 January 2014 - 05:46 PM
Very helpful topic, I'm experiencing the same problem now in my 1980 Mini 1000.
I've followed the haynes and used Cowboy's trouble shooting guide and from it, can conclude that there is a problem with the dizzy.
However, the points are opening and closing as they should and they're well shielded cables nowhere near the baseplate.
Really struggling for ideas so here's my cry for help!
Chris
