How full should the clutch master cylinder be? Verto if it maters.
If it's low, will a top-up need a bleed to make any difference?
Clutch Fluid Level
AlexP
, Feb 05 2010 04:32 PM
3 replies to this topic
Posted 05 February 2010 - 04:32 PM
Posted 05 February 2010 - 08:17 PM
bump
Posted 05 February 2010 - 10:23 PM
Couldn't tell you about the level of fluid needed as I'm not sure if Verto master cylinders are different to non-verto, but topping the cylinder up does not need a bleed unless the fluid is so low that air could enter the piping.
Posted 05 February 2010 - 10:47 PM
Fill upto the top but not including the neck, as above if its seriously low then it will need bleeding.
Get another set of hands to make it easier and bleed it anyway as I'm not sure how much the fluid drops when pedal is pressed so yours could be sucking in air if it was quite low. Best to be on the safe side, top up and bleed as its easy to do.
