Recommended Welding Clamps For Body Repairs
19 replies to this topic
#1 pickupapickup
pickupapickup
  • 77 posts
Posted 04 February 2010 - 11:09 PM
Hi guys, in need of advice and guidance on what welding clamps you would recommend for welding various panels, first off I guess knowing what panels need welding would help you out, so the list as follows...
-Floor pans
-Outer sills (possible inners aswell)
-Heel board (where rear subframe mounts to)
-Each corner of the scuttle
- Whole front end including flitch panels,
-Rear valance
-Door steps
-Arches
Using that info, what clamps would be suitable for tackling each job? Thanks in advance Ian.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 05 February 2010 - 08:27 PM
-Floor pans
-Rear valance
-Door steps
-Arches
Try these for door steps - http://cgi.ebay.co.u...c#ht_786wt_1165
Try these for arches - http://cgi.ebay.co.u...1#ht_874wt_1165
Try these for floor pans flitch panels, scuttle - http://www.frost.co....o...(pack of 5)
The vice grips come in various sizes from tiny upto very large, i use the on valance panels, inner outer sills, door steps.
The skin pins i use on most things as they are very versatile (cleco pins are all metal and as such do not melt but you will need the special pliers that go with them)
The intergrips are ideal for flitch panels, floor panels as they only need a small gap to be used.
I f you have a look under complete mini rebuilds for Project Erm you will see where i have used most of the above tools/clamps.
There are other products out there but these are what i have to hand and fill all my requirements.
Hope this helps
#3 pickupapickup
pickupapickup
  • 77 posts
Posted 05 February 2010 - 08:53 PM
Top man! Appreciate your reply, I'll definitely have a wee goose at your project, those intergrips look very handy. Would I be correct in saying the rivet pins are just like removable rivets, so after the welding is complete you simply weld over the small holes created by the rivet pins?
#4 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 05 February 2010 - 09:56 PM
Yes just weld them up though they are not rivet pins as such just temporary clamps. If you are thinking about purchasing some then i would recommend yellow 1/8th and blue 5/32 but as i mentioned the nylon pads will melt so it may pay you to use the Clecos in the same sizes just remember to buy the pliers as well. These will not melt.
The other thing to remember about the skin pins is that as well as coming in different sizes that come in different grip ranges. If i remember tomorrow i'll take a photo to show you what i mean. It basically means the thickness of metal they will grip.
#5 mini670
mini670
  • 293 posts
Posted 06 February 2010 - 08:55 AM
The intergrips are very handy, avalible from frost, or if you have a spare hour you can make these yourself. Ive used intergrips for flitch and floor panels, and some areas on the boot floor. Harddrive magnets are also quite good to hold pieces in place.
For my seams on rear arches and boot floor, ive used small G-clamps and vicegrips.Thinking of purchasing some cleeco clips when i get frount to the front end.
a couple of photos showing the intergrips in use
#6 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 06 February 2010 - 11:42 AM
As promised photo of the skin pins showing two different sizes and the difference in grip range. Blue 5/32, Yellow 1/8th
If you look at the right yellow skin pin you can see where i have melted the nylon base, not the end of the world as it is still useable.
Pins in use.
I use the longer grip range ones through thicker skins or multiples of skins.
Neil
#7 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 February 2010 - 04:35 PM
Photo of all the clamps pins that i use for my welding
Should give you an idea of the size of 'C' clamps that i use.
Neil
#8 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 February 2010 - 05:29 PM
Out of interested how do those intergrips work? i mean once you have welded the panel in place how do you remove them?
#9 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 February 2010 - 07:35 PM
Basically they are a flat thin piece of steel with a round pin through it, the flat plate goes between the items to weld, the round pin is installed and by doing up the butterfly nut the round pin is pulled up and clamps the material in place using the pin on one side and the frame of the intergrip on the other.
To release undo the butterfly nut and remove the pin and its as simple as that. I should add that you do need to get access to the pin so you cannot use the intergrips in an enclosed area.
Hope that explains it for you.
Neil
Edited by sonikk4, 11 February 2010 - 07:38 PM.
#10 jayare
jayare
  • 2,093 posts
Posted 11 February 2010 - 07:37 PM
For the Intergrips, loosen the wingnut and then remove the pin from the underside of the panel - the strip that the pin fits through then comes through the joint and then you finish welding the gap. Can't be used if you can't get to the back of the panel once welded, obviously.
The pins you need a special tool to remove them but they can be used into box sections and the like as you don't have to get behind to remove them.
JR
#11 pickupapickup
pickupapickup
  • 77 posts
Posted 14 February 2010 - 05:00 PM
There seems to be quite a few available brands of clamps to choose from, anyone have any preferences, I was thinking on getting a couple of the Clarke sets. anybody have experience using them? Thanks for all your replies been interesting reading.
#12 pickupapickup
pickupapickup
  • 77 posts
Posted 16 February 2010 - 11:52 PM
Anyone?
#13 kez_19
kez_19
  • 946 posts
Posted 17 February 2010 - 06:55 AM
these can be useful for getting panels in the same height or holding things at 90 or 45 degrees
michael
#14 kez_19
kez_19
  • 946 posts
Posted 17 February 2010 - 06:57 AM
mine are called "vice grip" made in the us and are great quality i would highly recommend them as i have mine for over 10 years and they are still as good as the day i bought them and i use them professionally
here are the ones i use
i would suggest you get the type in the link or similar with the release handle not lying on the bottom arm as most f the cheaper ones do as they can be easily released when you are using them, whereas the ones i have don't come undone whilst you are using them only when you press the release lever making them much better for your knuckles
michael
Edited by kez_19, 17 February 2010 - 07:02 AM.
#15 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 18 February 2010 - 10:09 PM
Try these and these.
I use both of these sizes plus i also have this type as the swivelling pads are ideal for gripping/clamping awkward angles. :unsure:
