Starter motor?
Posted 27 October 2005 - 08:12 AM
Its weird because sometimes mini will be absolutely fine all day, starting first time. And then when you stop it decides its had enough, makes me wonder if its just a loose connection. Any pointers where to look?
Any help is appreciated. Thanx sarah
Posted 27 October 2005 - 08:36 AM
Do you always get the clicking noise when it won't start?
Posted 27 October 2005 - 09:11 AM
It is definately not a flat battery have checked and got full charge
I wouldn't rule out a flat battery just yet, i've had this problem on a few cars, the battery can read fully charged and still have dead cells. I had cars with clicky starters and a jump start will get it started but the next time you turn it off and try again same happens. The starter soleniod could be another possibility try putting the car in gear and with the handbrake off rock it back and forth it can sometimes free it off. Then try starting again remembering to take it out of gear :grin: Trust me i've forgot loads!! Another is get a length of wood or socket extension bar and tap the starter solenoid .
Good luck let us know how you get on
Karl
Posted 27 October 2005 - 09:36 AM
Posted 27 October 2005 - 10:31 AM
Karl
P.S the wifes MX-5 has this problem right now if she doesn't drive it for a couple of days the starter will just click. A jump start gets it going no problems, same happened last winter a weak battery doesn't like the cold weather!
Posted 27 October 2005 - 01:25 PM
when you turn the key, it just goes... 'GONK' and nothing gets to the engine, not even a splutter. Apparently, I heard that the starnet motor sometimes just gets stuck. So if you t**t it with a rubber mallet that fixes it sometimes. I bounced it, pushing down on the wing up and down for about 10 sec, sometimes that works. Failing all of these, just push it allong, get some speed, jump in, drop it into second. ta daaaa, engine springs to life. Bear in mind that the last one there can sometimes get a bit hairy. lol.
Posted 06 October 2013 - 06:05 PM
I've been having the same problem. It's definitely not a problem with my battery as it's brand new, the car jumps fine from another car, but as soon as I cut it, the clicking starts again. So I've narrowed it down to a knackered starter motor.
Posted 06 October 2013 - 10:38 PM
Are we talking about a inertia starter with solenoid on the wing, if so bridge the 2 contacts if it cranks the solenoid is faulty if it does not crank then and your sure all the connections are good its internal on the starter and could be dirty comm.worn brushes/ dead segments on comm or just a tired worn out starter motor, same tests apply for the pre-engaged.
Ensure all battery connections and earths are good first though and check for volt drop to identify bad connections as here http://www.theminifo...ring-volt-drop/
