6x9 Sounds Rubish
11 replies to this topic
#1 micrawavewindow
micrawavewindow
  • 609 posts
Posted 02 February 2010 - 10:33 PM
why do my speakers sound rubbish i have fitted them in the kick boards but they sound well tinny and when i turn the base up it distorts they are 150 watt rms which i know is not mint but they should sound better i think i am also gonna fit a set to the back shelf but are they gonna sound just as rubbish. should i amp all the speakers up will this improve the sound. my stereo is a kenwood which has an output of 50 watt per speaker
should i change just one of the wires around and unplug the other until it sounds good then do the same as before
Edited by micrawavewindow, 03 February 2010 - 08:17 PM.
#2 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 02 February 2010 - 10:40 PM
That's an output of 50W max per channel...normally it'll be around 17W RMS. Turning up the volume all the way on the HU will result in clipping - instead of a nice sinusoidal wave output, it'll be much more like a square wave. Speakers don't like this one bit, and this causes distortion. Do it for long enough and your speakers will be permanently damaged.
So yes, amping the speakers, and setting the gains carefully and correctly will make them sound better. However, they shouldn't really sound tinny even when powered from the HU, I'm not sure why that is the case?
#3 mars red mike
mars red mike
  • 1,500 posts
Posted 02 February 2010 - 10:48 PM
If one speaker has been wired out of phase (wires back to front) they will sound very tinny with no bass.
#4 micrawavewindow
micrawavewindow
  • 609 posts
Posted 03 February 2010 - 05:27 PM
i think this is the case with the wires back to front how do i tell or should i just change them round and see if it makes a difference
#5 westpark15
westpark15
  • 133 posts
  • Local Club: mini drivers club
Posted 03 February 2010 - 07:29 PM
The only suggetion is that u ain't got good enough speakers personally I have jbl 300 watt ones and they are brilliant .
the wires on the other hand being the wrong way doesn't matter due to that a speaker has no polarity which means it will work either way :)
#6 northy
northy
  • 204 posts
  • Local Club: LCMOC
Posted 03 February 2010 - 07:34 PM
That's not quite right, westpark.
If the speakers are in opposite phase, it will make them sound rubbish.
And the power rating of the speakers is how much it can take, a good 100w speaker will sound the same at 50w as a good 400w one, it's a matter of the amplification.
I would imagine that what you are describing, OP, is a result of the puny HU internal amp, any speakers will sound better and bassier with an amp.
#7 samsfern
samsfern
  • 5,243 posts
Posted 03 February 2010 - 07:36 PM
i have jbl 300ws under the rear seats, and sound quite good, im guessing you have an up to date headunit, maybe you need to play around with the settings a bit?
#8 micrawavewindow
micrawavewindow
  • 609 posts
Posted 03 February 2010 - 08:16 PM
hi i have a kenwood head unit but it has no perament live i dont know if that matters but i will be changing the wires around tommorow to see if that help i have had these same speakers in other cars and they sounded really good with plenty of base i dont really want asub but i might have to get on if i can t fix these
#9 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 04 February 2010 - 02:59 AM
Sounds like the wires are the wrong way around. Yes the polarity matters.
#10 micrawavewindow
micrawavewindow
  • 609 posts
Posted 04 February 2010 - 08:52 AM
well this morn i unplugged one and the other sounded really really good so i achange the wires around on the one i dissconnected and guess waht, now my car rocks again thanks so much and i learnt sometr so all good thanks guys
#11 glennthrower
glennthrower
  • 296 posts
  • Local Club: Mini Freakz of Sussex
Posted 05 February 2010 - 10:01 PM
I would say, wiring the other way round changing the polarity, which apparently the human ear cant hear. Just what i think.
G
#12 micrawavewindow
micrawavewindow
  • 609 posts
Posted 06 February 2010 - 10:31 AM
when the wires are the other way there is no bass and loads of distortion try it. with the wires the right way it sounds like music again
