Warning Lights?
12 replies to this topic
#1 Foxy10
Foxy10
  • 387 posts
  • Local Club: Crewe's Missiles
Posted 01 February 2010 - 06:35 PM
what do the orange warning lights on the right an the left of the speedo mean? iv had a seach an mr haynes dosnt seem to know either?
cheers in advance :(
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 February 2010 - 06:38 PM
orange one is you charging light (lights if battery is not charging)
and the red one lights if you have no oil pressure (turn engine off quick)
#3 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 01 February 2010 - 06:40 PM
Don't think he meant those ones Bungle, Think he is talking baout the ones at 3 and 9 o'clock
#4 Foxy10
Foxy10
  • 387 posts
Posted 01 February 2010 - 06:42 PM
^^^Yeh the 1's at 3 an 9 o'clock
cheers
#5 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
arnt those indicators?
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 01 February 2010 - 06:44 PM
the green one at 50 is the indicators
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 February 2010 - 07:04 PM
If you have both, and both are actually functional and connected to something, one is low oil pressure and the other is blocked oil filter. Both mean stop and turn the engine off NOW.
#8 dorrian230
dorrian230
  • 13 posts
  • Local Club: Themes Valley Mini Club
Posted 01 February 2010 - 07:06 PM
Hay ho,
Pretty sure they corrispond to the smaller gauges either side of your speedo. e.g left hand one for water temp right hand one for oil prssure.
Mr Haynes doesn't cover them directly but if you look at the wiring diagrams i'm pretty sure they are part of them.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 February 2010 - 07:29 PM
Will everyone please read the large pink notice at the top of every technical section page.
When fitted as OE, if the car had extra gauges with the centre speedo the oil pressure warning lamp was not fitted. The oil filter lamp was still used on early cars (except automatics) even with an oil pressure gauge but was deleted at Mk3 I believe.
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 01 February 2010 - 07:41 PM
what Dan says is right :(
But if you aren't fussed about originality you can do the following with a slight rewire
use the orange for left and right indicators
the green for oil pressure warning
red for ignition
#11 Foxy10
Foxy10
  • 387 posts
Posted 01 February 2010 - 07:50 PM
this is what my gauges look like:
iv noticed the left 1 com on a couple of times but then go off again ne idea wtat it is? the temp gague (left 1) seems 2 b fine.
cheers 4 the replys :(
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 February 2010 - 08:33 PM
It is unlikely that you have a sensor filter head because they are quite rare so it's probably a low oil pressure warning. To be honest the lamps are pretty much interchangeable depending on where they are pushed into the instrument, if you can look behind it you can see what colour wire runs to it and check if there is an oil pressure switch on the engine with the same colour wire. The lamps are nothing to do with the temperature gauge.
Please don't write in TXT SPK.
#13 njathind
njathind
  • 447 posts
  • Local Club: Chichester Mini Club
Posted 07 February 2010 - 07:50 PM
My brother has a 1960's morris minor 1000 and it has the exact same clock, on his morris the blue is for full beam, the red is for the charging of the battery, the left orange is not used it is just to be symetrical and the right orange is for the oil filter, the mini is based on the morris minor 1000 to some extent and uses a lot of the same parts so what I have told you about the warning lights should be correct.
I have 1998 1.3 mpi mini cooper so unfortunatly I cant help much when it comes to earlyier minis
Hope this is of some help
