How Many Bolts Needed For Fixing Bumper?
9 replies to this topic
#1 Saoirse
Saoirse
  • 120 posts
Posted 01 February 2010 - 01:40 PM
It's in the bodyshop right now so can't look, but how many bolts are needed to attach the front bumper? Apparently they aren't standard size either?
#2 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 01 February 2010 - 01:42 PM
Edit: Doh, im a muppet - forgot they were captive.... sorry :(
Edited by maryquant, 01 February 2010 - 01:44 PM.
#3 Ethel
  • 25,919 posts
Posted 01 February 2010 - 01:43 PM
None, there should be 1/4" captive studs on the bumper
#4 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 01 February 2010 - 01:44 PM
Yup and then nuts the other side.
There should be 3 of them. Although quite often they are rusted and ruined, in which case you can remove the studs, and fit nuts and bolts of a similar size.
#5 Saoirse
Saoirse
  • 120 posts
Posted 01 February 2010 - 01:49 PM
So I should get these, but what bolts do they go with?
#6 Ethel
  • 25,919 posts
Posted 01 February 2010 - 02:21 PM
I'm lost now,
Are you buying a new bumper or refitting one without the studs? Also confirm it isn't a Clubman front bumper.
#7 Saoirse
Saoirse
  • 120 posts
Posted 01 February 2010 - 02:25 PM
I'm lost now,
It's a mini rover 1991, so mk4. It's the original bumper but lost the bolts for it (or that's what the people at the body shop said), and they said they couldn't find any that would fit it.
What do I need to reattach?
Sorry for being a noob!
#8 Ethel
  • 25,919 posts
Posted 01 February 2010 - 02:38 PM
You can't lose the bolts, they are permanently attached, they might have snapped them off.
If they aren't snapped three 1/4unf nuts and some washers are all you need. If they are broken any small bolts will do once they've drilled out the old ones.
#9 Saoirse
Saoirse
  • 120 posts
Posted 01 February 2010 - 03:08 PM
Ah cool I get it, I think I was confused my minspares which offered bolts. I will see how that goes then!
#10 satvinder
satvinder
  • 557 posts
Posted 01 February 2010 - 03:13 PM
i was given a clean bumper that one of the bolts had be chopped of and as they where imperial threads i just cut the rest off and welded new ones on that where a metric thread, as i found random nuts and bolts, its worked a treat!!
