Rear Subframe Removal?
Posted 31 January 2010 - 12:25 PM
thanks
finch661
Posted 31 January 2010 - 12:30 PM
Posted 31 January 2010 - 12:38 PM
Posted 31 January 2010 - 01:37 PM
Posted 31 January 2010 - 04:23 PM
Posted 31 January 2010 - 05:46 PM
just out of curiosity, is it easy to make brake lines?
Its like anything right tool and practise first.. Coil of brake pipe isn't expensive. And I think flaring tools are about £20
Posted 31 January 2010 - 06:27 PM
Posted 31 January 2010 - 07:15 PM
Posted 31 January 2010 - 07:26 PM
Posted 31 January 2010 - 07:29 PM
If you have basic mehcanicle skills then its a fairly easy job, even easier if you have a mate to help move it into place. Just a few things to look out for like not trapping fingers in radious arms!hmm im still debating whether to do this job by my self, or get a professional to do it. i have a feeling that if i try it, it will go horribly wrong
Theres plenty of guides on the good old tinternet to help you out. Do a search on google and do a bit of reading before you pay a fortune at a garage
Posted 31 January 2010 - 10:54 PM
Posted 02 February 2010 - 10:23 AM
can i run a quick breakdown past someone?
1) remove handbrake cable
2) remove exhaust
3) remove feed from 3 way brake connector (is there a special tool that doesnt round off the nuts?)
4) remove subframe bolts(ones near the grease point) - after using loads of wd40/heat
5) remove subframe bolts from the boot
6) remove shock absorbers via the big nust in the boot
lower subframe
now how easy is it then to strip the subfram, like removing the radius arms and so on?
Posted 02 February 2010 - 10:56 AM
Posted 02 February 2010 - 11:02 AM
just like thatradius arms are easy to take off, as are shocks, drums, cylinders and thats about it! simples!
Posted 02 February 2010 - 11:43 AM
