What Is My Engine?
Posted 27 January 2010 - 10:53 PM
Posted 27 January 2010 - 11:03 PM
iv been told that my engine is a 1275 cooper s. is there any way to check this? from what i know the cooper s has no removable cover for the tappets but im not sure if that is true. i think iv got the wrong carb too, i think its from a 998cc which is making my car run poo. Whoever had the car before my has put the 1275 in it, but i dont know anything about it, like year ect. how do you find these things out? any help would make my life alot easier. thanks
Have you got the engine number (should be stamped on a plate located to the right hand side of the engine (towards the front of the Mini))?
Not sure what the difference was between the Cooper and the Cooper S (unless the S featured the Works pack? - anyone confirm this?)
Posted 27 January 2010 - 11:53 PM
The S engine has an additional bolt(not stud) in the head.
Posted 28 January 2010 - 12:11 PM
What age is the car?
Posted 28 January 2010 - 12:23 PM
Apparently some mk3 S engines we solid blocks, but personally that just makes it a 1300GT engine which are still good, but dont have the same 'kudos' as a proper S engine....
Re the engine number, if it starts with a 12 then it is DEFINITELY NOT AN S ENGINE, S engines had their own bespoke engine numbers which did not follow the 8/9/10/12 cc prefix rule.
Finally, if it's an A+ block, no point even going any further. must be an A series..
Posted 28 January 2010 - 12:28 PM
Posted 28 January 2010 - 05:33 PM
Posted 28 January 2010 - 07:30 PM
The nearset thing you'll get to a cooper S engine in a 'later' mini are those which have a JCW conversion, and even then it's just a beefed up metro engine...
"Real" cooper S engines stopped being made in 1971
Posted 28 January 2010 - 10:46 PM
to check if yours is a S block you will need to check crank for an EN40B crank, block will have 11 stud holes and tappet chest covers and a non drilled petrol pump with a Ally plate with 1275 raised stamped on it rivitet to pump position with a engine NO: rivet...................
Posted 29 January 2010 - 02:50 AM
No... They are Cooper Sports.... not Cooper S
Not to sound dumb but what does the "S" stand for in Cooper S then? Minis can be sooooo confusing cause there is a model for everything, I'm surprised they didn't have the "Sir Alec Birthday edition Mini". Anyhow, I checked on the Austin/Rover site and it says my "Cooper S" engine puts out 77BHP stock. Austin Rover
Posted 29 January 2010 - 06:12 AM
As you say, yours is a Cooper Sport Mpi, although pushing out a similar power to the original spec 1275 cooper S engine, mechanically it's a different bestie altogether.
Posted 29 January 2010 - 09:16 AM
thanks
Posted 17 May 2010 - 11:24 AM
