No Dashboard Lights
11 replies to this topic
#1 LESTA MINI
LESTA MINI
  • 492 posts
  • Local Club: 4th Gear Mini Club
Posted 19 January 2010 - 11:14 AM
hi guys,
while driving my mini down into the village this morning to get it fixed while im at college. i notcied that i had no dashboard back lights. the speedo and everything was working and so where my main and full full lights. as far as i can tell everything else in the car is working.
guessing this just means a blown bulb but just wondering.
dan
#2 nile-jackson
nile-jackson
  • 155 posts
Posted 19 January 2010 - 11:15 AM
or fuse?
#3 LESTA MINI
LESTA MINI
  • 492 posts
Posted 19 January 2010 - 11:20 AM
see i though about a fuse but as every other electrical system is working on the car i guess it cant be that
#4 minimadrobinson
minimadrobinson
    Starting My Mini Up
  • 4 posts
Posted 19 January 2010 - 11:31 AM
Are your rear lights working?? i know it sounds silly but when my dashboard lights stopped working so did my rear lights and turned out they were on the same fuse!
If not check your bulb...good luck
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 19 January 2010 - 11:39 AM
Like mentioned check the fuses, side lights, rear lights and dash lights come off the same circuit
#6 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 19 January 2010 - 12:00 PM
Most likely just a bulb. Take the instrument panel out and swap one of the other bulbs (oil warning light) with the speedo back light one. The bulbs are all the same.
On my mini I had one of the thin copper strips on the circuit board behind the instrument panel break. All I did was wedge a piece of wire between the bulb terminal and follow it around the circuit to where the other end of the copper strip joined another bulb. Worked a treat. Hope this happened to you but if so here is the solution.
#7 beentheunseen
beentheunseen
  • 198 posts
  • Local Club: Notts about Minis
Posted 19 January 2010 - 07:01 PM
Mine has a loose connection on the plastic multi-pin plug that goes into the back of the instrument panel. I sometimes have to reach under the dashboard wiggle it a bit to get the lights to come back on...
#8 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 19 January 2010 - 07:06 PM
I normaly just give the clocks a good bash on the side. Seems to solve this problem every time. :)
#9 Steve McMaster
Steve McMaster
  • 26 posts
  • Local Club: LSMOC
Posted 27 February 2010 - 04:14 PM
Ahhh - I have suffered exactly this after breaking down in the rain on Wednesday - anyone know which fuse is the dash / rear lights, and do you know if they also run the fog light?
Ta
Steve
#10 djdobson
djdobson
  • 150 posts
Posted 27 February 2010 - 04:17 PM
could be the switch for the front lights. my dash lights stop working every now and again aand i found out that it was a dodgy connection on my light switch
#11 Steve McMaster
Steve McMaster
  • 26 posts
  • Local Club: LSMOC
Posted 27 February 2010 - 04:27 PM
Thanks - will check it out....
Wednesday was a seriously bad day, Stopped at a garage and went to start her again and nowt, not even a light on the dash. Seems the alternator had not been charging, so, called out Green Flag, and they jumped me and off I went, only to find out that I had no tail lights, so I had to stop and call them out again to be delivered home - 60 MPH on the A3 with no lights is not fun!!!
#12 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 27 February 2010 - 05:43 PM
This used to happen to me EVERY day. The dashboard lights would come on then go off, and then i realized this meant my rear lights also wouldnt work while the dahsboard lights were off.
Check the fuses. Mine werent blown but the connection in the holder wasnt correct. i think it was the bottom fuse that would move about in the fuse box. I just wrapped a bit of foil around it until i get i new fuse box thing.
Hope this Helps
...Alex...
