Extra Fuse Box Advice
Posted 18 January 2010 - 01:37 PM
Zeroasylum
Posted 18 January 2010 - 01:47 PM
Posted 18 January 2010 - 03:03 PM
Posted 18 January 2010 - 03:23 PM
Youn can take it from the solenoid....... however to do this you really would need to add a relay to switch it via the auxilliary circuit of the ign sw. this will then cut out the extra circuits as you turn the key to start the engine
Dont suppose you could provide a quick list of where to connect the relay. I would like it live even when the engine is off.
Posted 18 January 2010 - 04:28 PM
Posted 18 January 2010 - 05:06 PM
but do you want it switched from the ignition switch or live all the time ?
Live all the time as want to run audio equipment off it and would like to use the radio without the ignition on.
Posted 18 January 2010 - 05:34 PM
Posted 18 January 2010 - 05:44 PM
Posted 18 January 2010 - 07:32 PM
Posted 18 January 2010 - 07:36 PM
Posted 18 January 2010 - 07:39 PM
How much clearance do you have?? I would be worried about engine rock when you pull away.
I rewired my own front loom and mounted all the fuses in the dash, 15 in total and one spare. The wet can't get them as easily this way.
Posted 18 January 2010 - 07:42 PM
Posted 18 January 2010 - 08:27 PM
Putting the relay in the AUX system does this safely
Posted 18 January 2010 - 08:35 PM
Engine off but ignition on, is the AUXILLIARY circuit..... and when driving along the AUX is live..... it only cuts out whilst cranking the engine
