Might not work outside in the cold, the chimney should really be protected from the cold to encourage the fire to 'draw', worth a try though.how about making an oven outta one of these bad boys
http://cgi.ebay.co.u...=item3a56ae44f9
so you have the burner bit a the bottom and then a lil way up you have a bit were you put food that is sealed from the rest of it with a lil gap up the back for the smoke and obviously a chimney
Hows about chimney running inside oven
Edited by minimender, 12 January 2010 - 10:43 PM.
