Calor 15kg Gas Bottle
Posted 11 January 2010 - 11:29 PM
I'd like to build a temp wood burner to warm the new house whilst i work in there. I dont want to buy a new one and then make a mess of it whilst im working. when im finished i'll move the gas bottle to the garage and buy the new burner for the front room.
Or does anyone know where i could pick one up from. I've searched ebay but there's nothing local.
I've got a feeling the local tip wont let me have one, they dont like anyone taking anything out once its in.
Which is annoying because they have loads in a cage but i'll ask next time im up that way anyway.
And im going to ring the local gas supplier tomorrow but again im guessing the answer will be no. I no how annoying it is when you get people coming round asking for scrap metal.
But surely they must get the odd scrapper in?
Thoughts and comments welcome.
Mark
Posted 12 January 2010 - 09:21 AM
fire basket
Posted 12 January 2010 - 12:45 PM
Posted 12 January 2010 - 12:55 PM
Pikeys usually leave a few amongst the rubbish when thy move on, lay bys are a good place to look as well.
lol yea i did go have a look at the last place they were but the local council is quite good at cleaning up stuff like that.
i didnt think of laybys, good suggestion.
Posted 12 January 2010 - 01:00 PM
Use an old washing machine!! thats what I did anyway!. Just unbolt the drum from inside the body, turn it upside down and then bolt it back on. Something like this...
fire basket
nice idea. unfortunatly i need to use this inside
i can see my house filling quite nicely with that. dont fancy turning out to my own house, that would get a bit embarassing down the station lol
this is more what i had in mind, i've already got a flue in the fire place, i just need a burner to connect up to it.
Posted 12 January 2010 - 01:27 PM
And that picture looks like a 19kg Propane - a big one.
Posted 12 January 2010 - 01:30 PM
Lots of info on the internet and a good cheap log burner. I've got one in the garage..
Posted 12 January 2010 - 01:40 PM
http://www.hotpod.co.uk/
This guy was on one of those "Pay off your Mortgage in 2 years" type programs - ages ago.
Posted 12 January 2010 - 07:36 PM
Posted 12 January 2010 - 09:50 PM
Made it from one of those pink gas bottles that they use to fill air con systems on cars, I thought it might be a little thin walled for the job but it proved to be brilliant. Needs a regulator in the pipe though as he has to half cover the top of the pipe with a slate or something to slow down the burn once it has got going.
Cant upload the pictures , sorry.
It has a door in the front and a circular regulator which can be closed when it gets going, the bottle is upside down and standing on the valve gaurd with a piece of two and a half inch exhaust pipe welded in the top centre. The pipe is about 3 feet long (nearly a metre)
Posted 12 January 2010 - 09:59 PM
Posted 12 January 2010 - 10:15 PM
what do ya think ? Designed to be held down with metal tent pegs.
Edited by minimender, 12 January 2010 - 10:16 PM.
Posted 12 January 2010 - 10:28 PM
might have to get one made to take camping
Posted 12 January 2010 - 10:31 PM
Needs a slightly longer pipe really and a butterfly regulator in the pipe because it uses a lot of wood as it is.i like it
If you can shut it down by regulating the chimney then it will burn hotter and longer, it is hot now though and suprisingly light in weight.
It is also safer for camping than an open fire, uses less fuel, and with a bit of inginuaty (brains) you could make provision for cooking bacon on tinfoil and baked potatoes in foil in the fire.
luverly..
Edited by minimender, 12 January 2010 - 10:33 PM.
Posted 12 January 2010 - 10:39 PM
http://cgi.ebay.co.u...=item3a56ae44f9
so you have the burner bit a the bottom and then a lil way up you have a bit were you put food that is sealed from the rest of it with a lil gap up the back for the smoke and obviously a chimney
