Trouble Turning Over? Help Me Please!
21 replies to this topic
#16 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 13 January 2010 - 04:11 PM
All the solenoid does is chucks the starter gear into the right position with the flywheel - it is the actual motor that spins the engine over.
Sounds like you have a power issue at the starter......
if you have a seperate solenoid on the wing then ignore the above :dontgetit:
Edited by Wilson1330, 13 January 2010 - 04:12 PM.
#17 eden7842
eden7842
  • 907 posts
Posted 13 January 2010 - 04:15 PM
yeah but my solonoid wouldent hold itself in just kept clicking in and out, thats if i turn the key but if i bridge it, it works fine?
#18 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 13 January 2010 - 04:21 PM
Have you checked all the connections are tight and clean??
Is it a standard carb'd model??
#19 eden7842
eden7842
  • 907 posts
Posted 13 January 2010 - 04:26 PM
yeah its pretty much standard, my mate is on his way over with his relay so i can say yes or no to it being the issue.
i will double check all my connections wen i go back out in a mo.
thanks for the help
#20 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 13 January 2010 - 04:30 PM
The reason i ask is that my carb'd mini doesn't have a starter relay so i am guessing you have an spi type model?
#21 carthy79
carthy79
  • 45 posts
Posted 13 January 2010 - 05:20 PM
Some carbed minis do have starter relays, mine has (1990 998 with hs4 carb;
http://www.minispare...=...Y BLACK BOX
#22 eden7842
eden7842
  • 907 posts
Posted 13 January 2010 - 05:26 PM
the loom is a h reg so 1990?
that the one carthy79 thanks :dontgetit:
