Positive Crankcase Ventilation
Posted 10 January 2010 - 02:43 PM
Is this a sensible layout? Should i change the tappet chest breather to include a cannister? And what should i do about the connection on the rocker, should i change my rocker to one without a breather or plumb it into a PCV valve?
Sorry for the long post,
Rich
Posted 10 January 2010 - 04:09 PM
No probs with the long post, a good description is an advantage.
Posted 10 January 2010 - 04:16 PM
Posted 10 January 2010 - 04:40 PM
Posted 10 January 2010 - 04:57 PM
So to confirm, for positive crankcase ventilation, do not connect the rocker to the PCV valve?
I am now unsure whether to leave the rocker open-to-atmosphere or fit a vented filler cap?
Posted 10 January 2010 - 05:00 PM
Posted 10 January 2010 - 05:38 PM
Posted 10 January 2010 - 06:28 PM
So can you get different types of oil caps? some that can breathe and some that can't? Sorry if that sounds like a silly question.
Posted 10 January 2010 - 06:52 PM
http://www.minispare.....0GENUINE VE...
Posted 10 January 2010 - 06:55 PM
Posted 10 January 2010 - 07:46 PM
One of the reasons for constant depression breathers was to avoid fumes getting into the car.
Edited by Sherlock, 10 January 2010 - 07:48 PM.
Posted 11 January 2010 - 03:07 PM
Also, Sherlock, thanks for the idea, I might see if i can 'borrow' the breather from my dads frogeye restoration, he wont notice for a while, lol!
Posted 11 January 2010 - 03:28 PM
Posted 12 January 2010 - 12:31 AM
The non- breather cap is quite flat, only about 1/2 an inch deep & very plain looking, the breather type has a barrel-like extended portion which extends below the bayonet fitting pins in the filler neck & you will see a hole in the bottom of it of approx 3/16 inch diameter.Once again, thanks for replies. Is there anyway i can tell what type of oil cap i currently have fitted? (breather or non breather)
If your Dad's frogeye has the PCV, it will be the same breather system as fitted to the Mk1 998 Cooper & 1275 'S'. Just don't get caught 'borrowing' it! lol!
Edited by Sherlock, 12 January 2010 - 12:39 AM.
