How Hard Is It To Change A Clutch And Thrust Bearing?
8 replies to this topic
#1 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 08 January 2010 - 06:46 PM
as title says the thrust bearing is noisy so im thinking of having the engine out to change the clutch and a few other bits i want to do so how hard is this i have tackled most mini jobs so far so have a good idea od sockets and spanners etc :lol:
What am i really up against?
#2 mini13
mini13
  • 3,810 posts
Posted 08 January 2010 - 07:41 PM
Engine and box out, pull flywheel, remove transfer housing, seperate engine from box, remove centre main bearing, check crank and get reground in neccecary....
#3 Pauly
Pauly
  • 4,213 posts
Posted 08 January 2010 - 08:18 PM
Are you referring to the clutch release bearing as a thrust bearing? It can be done in the car, bit harder, and is easier with the engine out, but seeing as its an MPI I would have to think twice weather it would be better to just do it in the car.
Paul.
#4 mab01uk
mab01uk
  • 12,424 posts
Posted 08 January 2010 - 08:49 PM
What other 'bits' do you have to do? There is no need to take the engine and gearbox out just to replace a noisy clutch release 'thrust' bearing or the clutch itself.
(If you did mean the crankshaft thrust bearings then that is a different matter.........but then they don't normally make any noise.)
Edited by mab01uk, 08 January 2010 - 08:53 PM.
#5 mini13
mini13
  • 3,810 posts
Posted 08 January 2010 - 08:50 PM
Ah!
if as above you mean the release bearing, definatly do it in the car.
#6 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 09 January 2010 - 12:11 PM
Yeah its the release bearing thats noisey i want to have the engine out to paint it all up have the head off to etc so it will be coming out also want to have the subframe powder coated and all new hubs tie bars etc so its going to be all overhauled
#7 sirweste
sirweste
  • 75 posts
Posted 11 January 2010 - 08:10 PM
With the engine out it's a easy job.
#8 orcadian
orcadian
  • 203 posts
Posted 12 January 2010 - 08:48 AM
Hi,
Yes, a much easier job with the engine on the bench or floor (it can't fall anywhere from there) but you will need a flywheel puller for the later Verto type clutch - to extract the flywheel from the taper on the crank. Definitely be worth checking/replacing the deva pinion oil seal (the big red one around where the clutch plate fits) on the transfer case if it shows any wetness. Points to watch are: not mixing up the various bolts as some are coarse thread into alloy and others fine into steel/cast iron and torqueing everything on build up and replacing tab washers. Worth checking engine mount rubbers too. With the unit sitting on a sheet of ply, painting is easy and when you hoist it up again, you can do the underside if you intend doing the box (it wasn't painted originally on MPI)
#9 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 12 January 2010 - 08:57 AM
Cheers people i think i will be getting on with this as soon as its a little warmer outside :geek:
