Underseal
15 replies to this topic
#1 micrawavewindow
micrawavewindow
  • 609 posts
Posted 08 January 2010 - 05:52 PM
well as the title says will underseal set(i know it never sets properly) but will it ok to paint it in this weather and then leave it in a garage over night
#2 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 08 January 2010 - 05:54 PM
What will the temperature be like in your garage?
Probably not because paint cant set either under about 15 degrees
#3 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 08 January 2010 - 05:55 PM
i painted the subframes on my mini couple weeks ago using underseal.
was absolutely fine
#4 micrawavewindow
micrawavewindow
  • 609 posts
Posted 08 January 2010 - 05:57 PM
well it wont be warm but it wont be cold either not sure how warm but its colder than roon temp i am just worried about all this salt everywhere and my "herman" is going rusty NO OOOOO i hate rust
#5 arnie
arnie
  • 514 posts
Posted 08 January 2010 - 06:03 PM
why not get underseal in an aerosul and spray it on, ive been doing this today. remember to warm the can up infront of an heater first and shake well. it gives a much better finish aswell.
#6 micrawavewindow
micrawavewindow
  • 609 posts
Posted 08 January 2010 - 06:05 PM
i got 2 big tins of underseal already and gotta be honest i dont really care what the finish is like as its only underneathe and i cant see that so as long as its protected i dont really care
#7 arnie
arnie
  • 514 posts
Posted 08 January 2010 - 06:11 PM
warm the cans up before use then to make it easier to brush.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 08 January 2010 - 06:18 PM
i did some painting on the chassis of Dolly the camper last night
i surrounded the area with a dust sheet to keep the heat in and left a small fan heater in there with the thermostat set on low
#9 RetroRay
RetroRay
  • 836 posts
Posted 08 January 2010 - 07:24 PM
Your mini is likely to have been through a few winters and survived im sure it will be ok through this one ... id wait til the summer then you can do a proper job without worrying about wether your hands are going to fall off :)
#10 tomdale86
tomdale86
  • 298 posts
  • Local Club: k
Posted 08 January 2010 - 07:28 PM
slap it on with a brush-thats the way i did mine too- when on fine. i think because of its consistency it remains still brushable-mine was fine- and you want a good thick layer anyway.
if you want to make it a little easier, put the tin in the house maybe next to a radiator overnight.
priority is making sure you've cleaned the underside properly first.
#11 Boycie
Boycie
  • 1,978 posts
Posted 08 January 2010 - 07:33 PM
As said, would think underseal is ok to apply in this weather- it's good advice to warm it first though.
The question is, what are you painting it over?! :) :o
#12 micrawavewindow
micrawavewindow
  • 609 posts
Posted 08 January 2010 - 07:41 PM
well under the car is solid there is a little surface rust but i reckon wire brush it and then slap it on i will make sure there is no mud or dirt or anything just good metal(hopefully)
#13 Boycie
Boycie
  • 1,978 posts
Posted 08 January 2010 - 08:34 PM
Well in that case I would recommend a decent non-setting underseal like 'Hammerite underbody seal with waxoil'. I'd hope you can't buy the old-type stuff anymore that sets hard- it used to cause more trouble than good.
Before you apply it, de-grease, wash and then dry the panelwork first, as best you can. You really don't want to be trapping the recent road salt in there!!
#14 micrawavewindow
micrawavewindow
  • 609 posts
Posted 08 January 2010 - 08:37 PM
i have hamerite under seal with waxoyl so all should be good
#15 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 08 January 2010 - 09:02 PM
underseal or underbody shutz, rust generators, stone chip,paint and waxoyl best way to protect
