Boot Lock?!
Posted 08 January 2010 - 05:04 PM
Year: 1989
hey all, i cannot get into my boot!, i can get the key in but then its too ahrd to twist to unlock and i dont want to snap the key!
any ideas/tips to get the key to twist?
Posted 08 January 2010 - 05:13 PM
Posted 08 January 2010 - 06:10 PM
Posted 08 January 2010 - 06:34 PM
Edited by bmcecosse, 08 January 2010 - 08:19 PM.
Posted 08 January 2010 - 06:53 PM
Posted 08 January 2010 - 07:08 PM
using wd 40 and a lighter on my key and stuff no luck!
if i want to get in there do i need to drill out the lock and replace it?
what mk is my mini its a 1989
toby
Posted 08 January 2010 - 07:39 PM
just been out there... not good!
toby
If you want to get in there, just remove the 4 boot screws from the hinges and the lid will fall off.
It more than likely needs the lock greasing. Just undo the 4 nuts that hold it in, strip clean and regrease.
Salted!!
Posted 08 January 2010 - 07:46 PM
Posted 08 January 2010 - 07:48 PM
Posted 08 January 2010 - 07:49 PM
my sister needed jump leads last night, guess where they were
Edited by luiji89, 08 January 2010 - 07:50 PM.
Posted 08 January 2010 - 07:51 PM
thanks guys, will try this on sunday seeing as i have work 2moro
You should have pulled them out through the holes in the parcel shelf!!
Posted 08 January 2010 - 07:52 PM
Posted 08 January 2010 - 08:02 PM
Posted 08 January 2010 - 08:04 PM
I have to lift my key in the lock slightly as it turns to open my boot.... should have asked for a new lock for Christmas! lol
yeah! ive tried everything possible i think ill remove the whole boot and re grease it!
thanks guys!
edit: are the hinges bolted meaning ill have to get under the car or are they just screwed in? cheers
Edited by luiji89, 08 January 2010 - 08:26 PM.
Posted 08 January 2010 - 08:32 PM
