Paint Remover?
9 replies to this topic
#1 GOODY2BE
GOODY2BE
  • 204 posts
Posted 06 January 2010 - 11:12 PM
hi whats the best way to remove cellulose paint from my front end?painted it this time last year and it reacted so has been like bitumen ever since looks ok from a distance but lean on it and you leave your print >_< started to sand it but cloggs up disc really quick and will be tricky to remove from all nuts and crannys by sanding just wondered if there was a easier way?
#2 Joe-Richardson
Joe-Richardson
  • 10 posts
Posted 06 January 2010 - 11:16 PM
I put a new scuttle panel on my mini and it must have been coated with something because when we sprayed it about 5 minutes after the new paint cracked with a lot of black lines coming through. For me it was easy enough to completely rub down the affected part put another coat of primer then some coats of topcoat on. I wasnt using cellulose but acrylic.
#3 guywithvan
guywithvan
  • 1,081 posts
  • Local Club: MedwayMiniClub
Posted 06 January 2010 - 11:22 PM
linc's is pretty damp at the best of times let alone this time of year >_< no offence i have family there :D ,i'd reccomend waiting till the weather warms up untill respraying so you dont get a repeat of the current paint,as for removing it go to a paint supplier and get a 5 litre can of paint stripper (cheaper than nitromorse from b&q ect ) use that but you'd have to make sure all traces of it are gone before spraying and it can be very messy,remember to wear a good filtered mask too :( i got very high last time i used some.
other than that if the paint is still soft try a hot air gun on a low setting and use a scraper? might take a little time though
#4 micrawavewindow
micrawavewindow
  • 609 posts
Posted 06 January 2010 - 11:37 PM
try thinners not white spirit but proper celulose thinners its good stuff
#5 GOODY2BE
GOODY2BE
  • 204 posts
Posted 06 January 2010 - 11:39 PM
cheers, looks like it could be summer when all paint is removed and its too cold at moment to even think about goin in garage never mind paintin in it lol
#6 jack_marshall
jack_marshall
  • 2,540 posts
Posted 07 January 2010 - 12:02 AM
If its as soft as you say get your self a box of gloves, a bag of clean thick rag and a 5 litre tin of cheap cellulose thinner and scrub away.
Paint stripper can cause problems later on. Not sure why your paint never hardened though?
#7 AdamBilsy
AdamBilsy
  • 744 posts
Posted 07 January 2010 - 03:07 PM
Are you sure it wasn't 2-pack paint you used to paint it with?
#8 GOODY2BE
GOODY2BE
  • 204 posts
Posted 07 January 2010 - 09:20 PM
yup, not sure whats happened with it
#9 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 08 January 2010 - 12:00 AM
paramose non water based paint stripper
#10 feybrand
feybrand
  • 1,247 posts
Posted 08 January 2010 - 03:15 PM
you could sandblast it if youve got a compressor that would get rid of whatever caused it to react in the first place as well
