Fom The Clubman Estate
764 replies to this topic
#751 Tupers
Tupers
  • 4,176 posts
Posted 18 March 2016 - 08:51 PM
I've also been messing about with some slightly more detailed work for the interior Allegro/Marina door pulls I'm using.
The pulls themselves are nice chromed pieces but the original surrounds were black plastic which I'm not fond of so I started making templates for new steel replacements.
Once I'd settled on the new dimensions transferred them onto some 4MM steel and chain drilled out the centre section.
It was then clamped in the vice and I used a rotary bur to remove the excess before finishing it with a few files.
A quick test fit to make sure I was heading in the right direction.
The bucket on the back was a simple piece to fold up and was then gas welded on.
The pulls are nice and snug in their new homes. The plan is to have whole lot chromed and paint the inside black to add a little contrast.
I've also managed to finally get ahold of a set of innocenti door windows with opening quarterlights to add to the luxury theme I'm going for.
#752 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 18 March 2016 - 09:12 PM
Those rear windows really have come out great so far!
#753 Itsaminithing
Itsaminithing
  • 856 posts
  • Local Club: Not One Worth Mentioning
Posted 19 March 2016 - 01:42 PM
Phwar! non-standard self built mods.... now this is sexy -subscribed.
   & to think i only found this thread because i'm stalking Jared :wacko:
(in reality i did a forum search for leccy window conversions)
#754 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 19 March 2016 - 02:46 PM
O_O  :teehee:
#755 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 19 March 2016 - 04:46 PM
Hi Tupers, I've got a puzzler regarding my MG Metro radiator and seeing as I know you're using one I hope you'll help me. The temp sender on the side of the radiator, what holds it in place? I bought a sender but I'm left wondering now how it's kept in place, there is obviously some sort of clip but can't find any evidence of one anywhere online for buying one. Can you educate me regarding what's required?
#756 Tupers
Tupers
  • 4,176 posts
Posted 19 March 2016 - 09:16 PM
O_O  :teehee:
Quick Jared run!!!!
#757 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 21 March 2016 - 06:31 AM
Top work man love the look of this build. Making you a one off!
#758 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 21 March 2016 - 08:35 AM
O_O  :teehee:
Quick Jared run!!!!
:ohno:  :tumble:
#759 Tupers
Tupers
  • 4,176 posts
Posted 25 March 2016 - 06:35 PM
As I was happy with the fit on both window frame I warmed the MIG up and get them all welded in. I do enjoy welding thick steel.
There was a lap joint between the quarter and the section that holds the weather strip so I brazed it up.
I also welded the new waist rail sections in at each end and brazed the top edge
With most of the structure and mechanism sorted I moved onto deciding how to hide it all.
To try and keep an OEM feel to the conversion I decided lengthen the channel that holds the quarter trim in a Mini saloon.
Each side took 1 & 1/2 channels to equal the new waist rail and were clamped onto my bench to be welded together.
They were then clamped into the body and brazed on in a few spots.
Here's a test fit of an saloon quarter trim, obviously I'll be making new cards to span from the B-pillar to the seat back mounting post.
#760 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,184 posts
  • Name: Neil
Posted 25 March 2016 - 09:10 PM
Loving the detail Chris.
#761 skoughi
skoughi
  • 1,199 posts
Posted 06 November 2016 - 11:04 AM
Any updates on your estate? Kinda missing it!
#762 Magneto
Magneto
  • 891 posts
  • Local Club: KC MINI Club
Posted 09 December 2016 - 05:45 PM
6 years in the making ........so far!
C'mon, Chris, show us what you been doing!  O_O
#763 Chris1992
Chris1992
  • 2,022 posts
Posted 09 December 2016 - 11:53 PM
I'm actually having withdrawal symptoms from this project!  :lol:
#764 lawrence
lawrence
  • 1,341 posts
Posted 10 January 2018 - 09:38 PM
any new updates? missing this thread, just came across it again after searching for something else.
#765 wadeenie
wadeenie
  • 13 posts
Posted 29 January 2019 - 08:35 PM
It's dead :-p
