I'm still contemplating a BMW panoramic sun roof but I need to get some other stuff done first.
Fom The Clubman Estate
#736
Posted 05 June 2015 - 10:07 PM
#737
Posted 06 June 2015 - 11:43 AM
Do it ![]()
#738
Posted 06 June 2015 - 04:07 PM
#739
Posted 06 June 2015 - 04:16 PM
I'm holding out for one of the latter 2 piece opening roofs. It's definitely on the list.
That'll be really nice - luxurious as well.
#740
Posted 08 June 2015 - 07:08 PM
#741
Posted 16 June 2015 - 08:30 PM
So I'm back on the side windows again. My sheet metal folder is only 1 meter long so I had a fabrication company around the corner fold some 2 meter long pieces to hold the window channel.
I notched the corners and folded the ends in to make one continuous frame for the side window.
It fits in the back quite nicely so the next job is to make mounts for the window motor.
#742
Posted 17 June 2015 - 10:01 AM
I don't know how to spell a wolf whistle so as cheesy as that would be, i would type it if i could ![]()
#743
Posted 25 January 2016 - 08:04 PM
#744
Posted 26 January 2016 - 06:43 AM
This is just a cool build love how your making it "yours" and "different" will all those cool little touches :)
#745
Posted 27 January 2016 - 06:21 PM
Well that took a while to get through the 50 pages, top work done there will be watching this one
#746
Posted 27 January 2016 - 07:05 PM
Think it goes like wit woooooo haha
#747
Posted 14 February 2016 - 04:39 PM
Any news on this? Have read the whole thing over a couple of days and I'm keen to see how it turned out....
It's still languishing in the corner of the workshop I'm afraid.
We had a 2nd Crayford saloon and a Hienz Hornet come in for restoration last year and they did a number on my spare time.
If I'm lucky I'll be able to get back to it in a month of two but I'm not holding my breath.
#748
Posted 15 February 2016 - 12:36 PM
#749
Posted 17 February 2016 - 02:06 PM
Keep up the good work
#750
Posted 18 March 2016 - 08:16 PM
I've had a bit of down time between customer project at the workshop recently so I decided to jump back onto the roll down side window project.
I started by making a new intermediary pillar to support the back half of the drop glass frame. It also incorporates the flange for the rear quarter window seal and is tapered to account for the angle of the window frame.
Here you can see how the outer face of the pillar transitions from 90* the to top of the frame to 45* at the bottom allowing the glass to sit away from the quarter panel.
I wanted to move the drop glass frame as high as I could within reason so elected to remove the strip that the old window channel screwed to and cheat another 15MM of room.
With the strip gone the frame can sit right up against the cant rail.
I then marked out the remanning over hang and cut it off below the black line to reveal the entire wind opening.
The next issue to deal with was the step between the top of the quarter panel and frame.
As the frame will be welded in I elected to cut the outermost section off allowing the top to sit further out effectively using the quarter panel as the 3rd side of the channel.
The top of the frame and quarter panel are now flush and will blend into one another once everything's welded.
Another challenge having the frame welded in threw up was that one side would need to be removable to allow the glass to be fitted.
To save the removable to section from flapping about I made a brace to hold each side together using some flat steel bar.
This end is doglegged to stop the fittings from interfering with the glass as it moves up and down.
Each brace was welded on before the frame was split just bellow waist height at the B-pillar.
So here's how it will be assembled.
You start with the 3/4 section of the frame permanently welded into the body with its felt runners fitted.
The window can then be slid in from the front and pushed to the top.
Once the window's held at the top the remaining 1/4 section is bolted in place completing the frame.
After I lot more trail fitting, fabrication and head scratching I got the universal drop mechanism cut down to size and bolted in place.
I also folded up and new waist rail which will be welded in continuing the profile from the back and locating the inner weather strip.
Here it is in action.
