Interesting project
Fom The Clubman Estate
#661
Posted 09 February 2014 - 06:38 PM
#662
Posted 09 February 2014 - 07:49 PM
#663
Posted 11 February 2014 - 12:35 PM
what a build this is! great attention to details!
#665
Posted 14 February 2014 - 11:50 AM
I so want/need a Clubman estate!
#666
Posted 19 February 2014 - 08:05 AM
This is going to be beautiful when finished, keep up the good work.
#667
Posted 07 April 2014 - 11:38 AM
any updates?
#668
Posted 06 May 2014 - 08:49 PM
Well I'm back and I've finally solved my belt issues with a Peugeot 106 idler pulley and tensioning pulley. This should be easier to adjust than the other system I had and it looks much tidier.
I'm going to need a pretty long belt but I've got plenty of contact on all of the pulleys so it should work nicely.
#669
Posted 06 May 2014 - 09:02 PM
Tupers,
any more updates? i'm too greedy but the detailed work is mindblowing! i saw the previous post, did you tig welded the crossmember?
#670
Posted 07 May 2014 - 08:34 AM
wheres this gone?????
#671
Posted 07 May 2014 - 04:17 PM
He's a busy man guys, he'l update when he can be paaaaaatient
#673
Posted 07 May 2014 - 06:12 PM
#674
Posted 08 May 2014 - 08:09 PM
I forgot to go and buy a belt at lunch so I decided to spend this evening making the tabs to mount my seats from. They're pretty simple 3MM steel with 30MM slotted holes to help get the seats centred in the car.
They'll be welded onto sections of 30MM box running from the inner sill to exhaust tunnel. (I finally found a use for lime flavoured Starburst)
#675
Posted 08 May 2014 - 08:16 PM
Hahah, yeah nobody likes the lime starburst
Looks simple and effective construction Tupers, although i do feel this update has come too soon ..... Domdee needs to be hung out on updates a little longer
That metro looks like its had a fair bit of bodywork done upfront, looks like a perfect base for a good spray job and re-build, another returns from the pearly gates
Bing (1)
