them headlights will look the business!
Fom The Clubman Estate
#586
Posted 09 July 2013 - 05:48 AM
#587
Posted 10 July 2013 - 03:38 PM
Very cool build - are those headlights from a 70's Vauxhall, like a Victor or similar?
#588
Posted 15 July 2013 - 08:48 PM
The headlights I'm using are from a Capri. Some Wood & Pickett Clubmans used Vauxhall Victor lights and grills but they both use the same size headlights.
#589
Posted 16 July 2013 - 04:57 PM
I love the fabrication skills in this build, I admire a person who puts the effort in for the fine details. Keep up the good work.
Regards Blue
#590
Posted 16 July 2013 - 07:18 PM
Regards Blue
Cheers Blue, I do love the little details.
I dug out some 1.2MM steel this evening and cut out the pattern for the lower mounts.
These were a lot easier to fold than the top mounts.
All together.
#592
Posted 23 July 2013 - 10:41 PM
Ever thought about designing houses too Tupers?
I've designed many many houses although they were all small scale.
I had a bit of a play after work and made up the boxes that will be welded to the front panel and bolt onto the lower rad mounts. The thick plates will have captive nuts on them and will be welded inside the boxes.
This is more or less how they'll fit. To take the rad out I'll remove four bolts on either side and drop it down.
#593
Posted 25 July 2013 - 12:03 AM
#594
Posted 31 July 2013 - 09:25 PM
Love the fab skills bud but just on question? Would it not be easier to make the rad removable from above ?
I considered it but I really like having a clean slam panel and having a seam at each end a bolts in it would spoil that.
I thought I'd have a go at gas welding the captive boxes. Need some more practise but I really enjoying the process so far.
Got everything clamped in place. The bolts should be fairly easy to get to even with the engine in.
It sits quite nicely in the car.
I also started chopping the headlight backings up, I did cry a little when I remembered what I paid for them.
Most of the original headlight backing on the body has gone as well, this wasn't quite as painful.
Quad headlights are the bomb.
I've managed to get the quite far back, this should make for a nice deep grill.
#595
Posted 31 July 2013 - 09:54 PM
Excellent work Tupers, Them lights will look great.
#596
Posted 01 August 2013 - 05:32 AM
them lights give me a bulge!
#597
Posted 01 August 2013 - 07:35 AM
#598
Posted 01 August 2013 - 08:28 PM
loving the fab skills!! Quad headlamps look good, interesting to see what you do with the grill
Filbey
#599
Posted 04 August 2013 - 02:03 PM
#600
Posted 06 August 2013 - 09:09 PM
Bing (1)
