Fom The Clubman Estate
764 replies to this topic
#541 Tupers
Tupers
  • 4,176 posts
Posted 24 September 2012 - 08:09 PM
im loving the tailgate idea it makes me think about pinching my dads old pickup tailgate he has in his garage but i was thing what to do about the top half and it thought about using the top half of a fibreglass one peice.
That's not a bad idea that although I want to try forming a piece of 6MM lexan to the curves of the back end.
Absolutely love this project. Top work mate... Although you've nicked my idea of a split tailgate lol (not really haha...ive never told anyone just had it in my head for years lol) altho i was going to make it out of a one peice fibrglass and cut it in the middle and fibreglass the cuts up.
You probably have to add a lot of the strengthening to the inside or it would tear off if you put any weight on it but it'd be doable.
After much deliberation about how to lock the tailgate I've decided to go with a simple squeeze lock that will retract two pins from the door frame. Nice and simple and it'll barely cost me anything to build.
I started out by cutting a hole for the pinch tabs in the centre tailgate.
Then I drilled a hole in each side for the door frame for the pin to go into.
Last week a I cut a couple of thick steel squares and drill a 10MM hole in each to give the pin a little more support at each end. I've also spotted some little nylon top hats and the hardware store that I might insert into them.
The top of the frame was in dire need of strengthening so I made a top cap from 1.5MM steel and welded it on. This was unbelievably hard to bend but it's stiffened the frame up brilliantly.
#542 F1L8EY
F1L8EY
  • 600 posts
Posted 24 September 2012 - 10:01 PM
im on page 6 of 37... suitably impressed thus far!!
now to finish this thread... very comprehensive
:geek:
edit: there goes my early night... pg 37 of 37!!!
im down in Plymouth, didnt realise you guys were so close, i shall have to visit the workshop some time while passing to shake your hand.
top notch fabrication and welding. close attention to detail. i hope my future build is as well pieced together. keep up the great work
Filbey
Edited by F1L8EY, 25 September 2012 - 12:53 AM.
#543 Tupers
Tupers
  • 4,176 posts
Posted 16 October 2012 - 07:33 PM
I took a trip to the shops and found some nice 8MM i.d nylon stepped washers to use as bushes for the locking pins.
The holes in the tailgate and door frame needed drilling out to 11MM and then the stepped washers slotted right in.
I also picked up some 8MM mild steel rod to use for the pins.
After much chopping and welding I got one side 99% of the way there.
The mechanism still need a bit of tweaking but it's working the way I wanted.
#544 mike174
mike174
    BH2N Big Cheese
  • 457 posts
Posted 16 October 2012 - 07:49 PM
Cheating and using Unistrut Rail nuts? lol Looks good though
#545 Tupers
Tupers
  • 4,176 posts
Posted 18 October 2012 - 07:43 PM
Yeah I was rummaging around in the builders merchants saw them and thought 'yeah that'll kill two birds with one stone'.
#546 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 23 October 2012 - 12:30 PM
Its a shame you couldnt have a wind up window in the tailgate...
Great work tho!
#547 1989flame
1989flame
  • 179 posts
  • Local Club: half pint mini's,bmc
Posted 23 October 2012 - 03:39 PM
love the hinged rear light
#548 jonny f
jonny f
  • 1,493 posts
  • Local Club: Boxhill Mini Club
Posted 24 October 2012 - 06:36 PM
Great work as usual. That tailgate should look good!
#549 josrey
josrey
  • 92 posts
Posted 25 October 2012 - 11:59 AM
So here it is after owning 3 different minis and never using any of them this is my first proper project mini.
It's a '72 Clubman estate bought on ebay for £505, it's got rusty doors all round, rotted out sills, a hole in the floor next to the battery tray and stained head liner but other than that it's pretty solid. The plan it to strip it down the a shell, give it a complete rebuild and do a few subtle mods along the way. We only just picked it up today so so far all I've done it remove the interior and start to list what needs repairing, what need replacing and what I want to add to it.
I'll get some more pictures up once I really sink my teeth into it.
Looks Like An Epic Project I'll Keep Looking Through This Thread :)
#550 Willy_sa
Willy_sa
  • 93 posts
  • Local Club: MOCSA
Posted 06 November 2012 - 01:05 PM
Hey
I just read through your build on the mig welding forum and saw your interesting supercharger setup. I am planning somthing similar but with a different charger. What did you do to get space for the charger there? I also want to fit it between the motor and the radiator.
Great build by the way!
Mad metal skills!
#551 Tupers
Tupers
  • 4,176 posts
Posted 12 November 2012 - 10:46 PM
Thanks bud, I think epic's probably a pretty sound way of describing what I've gone through with this. :lol:
Hey
Mad metal skills!
I'll be sitting the alternator down at the bottom of the engine which means the oil filter will be getting relocated to the N/S of the front subframe. Looking at the engine lengthways the charger will end up in the 2 o'clock position to try and narrow it a little and the front panel has been notched so the radiator can sit about an inch further forward than it normally would be able to.
Nothing hugely groundbreaking just lots of careful thinking.
Progress on the estate has really ground to a halt recently as I've been busy on customer projects but I'm hoping to whittle out a little more time to get this rolling again.
I have at least been buying shinny things to keep me happy starting with a set of Dunlop DJ93 tyres at about 35% off. :D
I also got a nice steering wheel that's currently on it's way to me from Portugal, kudos if you can guess what it's from.
Today was one of those aforementioned days when I managed to whittle out a little time to get something done that should have been finished ages ago.
When I pulled the old boot floor out the old mounts for the rear seat also went. I'd made the new captive plates to remount the seat ages ago but didn't get around to fitting them until this afternoon. I also tock the opportunity to move the seat base up at the front and rear to make it easier to hinge and fit carpet underneath.
#552 jonny f
jonny f
  • 1,493 posts
Posted 12 November 2012 - 10:51 PM
Where did you get the dunlops from?
Edit:
Google says ebay haha.
Keep up the good work on the build!
Edited by jonny f, 12 November 2012 - 10:52 PM.
#553 89mini-boy
89mini-boy
  • 486 posts
  • Local Club: OXMOC
Posted 13 November 2012 - 06:27 PM
that steering wheels from an ABARTH :mrcool:..... :shy:
Amazing ideas absolutely bril to see something different getting harder and harder to find something different to do but amazing ;-)
Ashley
#554 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 14 November 2012 - 05:56 PM
I know this pic is of a mini van/sweet shop, but its the back end that reminded me of what your doing.....
#555 joezone2001
joezone2001
  • 332 posts
Posted 14 November 2012 - 06:53 PM
Haha, that's cool.
