Fom The Clubman Estate
764 replies to this topic
#511 Jossen
Jossen
  • 50 posts
Posted 12 August 2012 - 04:09 PM
Perhaps something without the vertical lines? They tend to make a Clubman look a little narrow and taller. The horizontal lines would work with the indicators to really make the front end look wider and meaner. (IMHO of course!)
#512 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 12 August 2012 - 04:30 PM
Got bored so did some eBay searching, is this the sort of thing your after?
Look at this on eBay:
Torques Remote Billet Aluminium Oil Filter Housing- Blue (AN-10 JIC-10) 3/4 UNF
eBay item number: 150865863148
#513 _mini1000_
_mini1000_
  • 236 posts
Posted 13 August 2012 - 05:24 PM
number 5 for me :)
#514 Tupers
Tupers
  • 4,142 posts
Posted 13 August 2012 - 06:46 PM
3 and 5 look pretty nice to me!
number 5 for me :)
Cheers guys I quite like 5 as well because I could make the centre emblem looks like an early Clubman one but a little taller and slimmer.
I see where you're coming from with that and I've got to agree so some extent. My only real concern is that with out something in the middle to break it up a little the front could just end up looking really flat and maybe a bit dull?
I could make something like work that but I'd rather have one like this where the pipes come out the front. But it wouldn't be a huge tragedy if I did end up with a side entry one.
I had a bit of spare time on Sunday between doing nothing and dong more nothing so I popped down and had a fiddle with my tail gate hinges.
I made these captive channels a while ago for the hinges in bolt to.
This is how they bolt up the the hinges.
The hinges go through the step sill and under the floor so I needed to make a hole to get to the bolts.
I started with a step drill and then moved onto the die grinder.
I still need to add some structure under the floor to weld the captive channels onto but the is roughly where the hinge should sit.
Edited by Tupers, 13 August 2012 - 06:47 PM.
#515 Tupers
Tupers
  • 4,142 posts
Posted 13 August 2012 - 10:57 PM
I had a go at making the closing plates for either side of the captive channels today.
Each one will have a curved lip that will be plug welded to the valance.
To make the lip I used a pair of long nose pliers to bend the 15MM at 90* to the rest of the panel but this left me with waves on the edge.
I decided I needed a tucking fork to sort them out but didn't have one so I made this one quickly
I slipped the fork onto each waved section and then twisted it counter clockwise to make the metal double over on it's self.
The more you twist the more of an overlap you get until you end up with an S shape where the wave was.
Once I had it over far enough I used a hammer and dolly to knock the S flat so it's just three layers of metal stacked on top of each other.
The radius on this one is off a bit l but I'll chalk that up to learning and make a replacement.
#516 DugganC17
DugganC17
  • 359 posts
Posted 14 August 2012 - 12:42 AM
Read from the beginning and what a great project it is and great work going on to. As for the grill I say go for number 5 keep up the good work :)
#517 Jossen
Jossen
  • 50 posts
Posted 14 August 2012 - 05:00 PM
I really don't think there's any chance that this'll look dull with all those little details to discover!
Edited by Jossen, 14 August 2012 - 05:00 PM.
#518 stretch tech
stretch tech
  • 1,363 posts
  • Local Club: A5 & Mini Mainiacs
Posted 15 August 2012 - 11:31 AM
hi pal, been watching this project for a while now, great work :proud: i'm very envious of your fabrication and welding skills :shifty:
i'd say #5 for the grill design too
can't wait to see this finished and how well that blow through charger works as i'm thinking of going supercharged next year or the year after but i don't know whether to go suck or blow through >_<
keep up the great work mate
Rhys
#519 DaveJH
DaveJH
  • 393 posts
Posted 15 August 2012 - 02:22 PM
Awesome progress as ever! I agree, 3 or 5 are nice designs.
#520 Tupers
Tupers
  • 4,142 posts
Posted 16 August 2012 - 08:27 PM
I'm going to do a full drawing on A3 so I think I may do it without the centre and then add it in if it needs it.
Thanks, I've said but before but the fabrication and welding skill just comes with time. I've just been fortunate enough to have spent time with the right sort of people to crib off so I've been on a slightly accelerated learning curve. The engine should be an interesting challenge as I've never really done much in depth work but I think I'll be OK.
Cheers, 3 and 5 are definitely the popular ones and fortunately my favourites.
I decided not to do the folded and tucked edge on the closing plates as I need more time to figure out the process. Instead I made 4 closing plates this afternoon that will have a curved piece welded to them to support the valance.
That was all I really got done for the car as I had a go at TIG welding. This is really my first proper attempt bar me destroying a few rods 5 years ago when my Dad first got this machine.
This is 4MM mild steel butt welded plus a few practice beads.
This is 1MM mild steel on my first shot at butt welding.
#521 grahama
grahama
  • 2,442 posts
Posted 16 August 2012 - 08:32 PM
Glad you are doint the closers again, the folded joints would only attract water and that's not good for a mini. Have you seen this site for making pannels
http://retrorides.pr...ad=65793&page=9
I'm sure some of the techniques could save you welding unless you want to learn tig welding !!
Graham
#522 Jossen
Jossen
  • 50 posts
Posted 17 August 2012 - 12:45 PM
Sounds like a good idea! Oh, and I was wondering about those radiator mounts; Will they mean you don't need to modify the rest of the Clubman front end to fit the radiator or does it still need help?
#523 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 17 August 2012 - 07:14 PM
great thread :thumbsup:
#524 axn1
axn1
    Just On Tickover
  • 5 posts
Posted 18 August 2012 - 09:46 AM
nice work, i´ve been reading this projectfile now 2 days, i dont have my own classis mini yet, but this inspired me alot! greetings from finland!
#525 Tupers
Tupers
  • 4,142 posts
Posted 18 August 2012 - 09:37 PM
Graham
I've actually got that thread saved in my favourites already, there's certainly some good techniques in there. The TIG welding is just a self improvement thing really, I'd like to do a TIGed chromoly cage in a Mini one day.
If I was going without the super charger I could get away without cutting the front panel but as I am I moved it forward by abut 25MM.
Thanks Johnny.
I'm glad it's got you inspired, I look forward to seeing what you do once you get your hands on a Mini.
7 user(s) are reading this topic
0 members, 7 guests, 0 anonymous users
